data base is stopped
  • Thread starter Thread starter Ronny
Ronny
Outlook Business Contact Manager used to work perfectly, now suddenly I get
an error which says cannot access the data base the data base has been
stopped.
Can anyone help
> stopped.
> Can anyone help
Look at your Windows Services. There should be one MSSMLBIZ
sqlserver.exe. If it's not running, start it, and set it to auto start.
Thanks Luther my problem is solved
> > stopped.
> > Can anyone help
F Outlook Data File Column Empty Using Outlook 3
CWM330 Saving Data: Don't check certain folders Using Outlook 2
CWM330 Importing " Old Skool" Data Using Outlook 0
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
Diane Poremsky How to Compact the Data File When you Close Outlook Using Outlook 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
Diane Poremsky Rename Email Accounts and Data Files in the Folder List Using Outlook 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
