Accessing Outlook 2003 Signature Programmatically using C#
  • Thread starter Thread starter Bachi
Bachi
I am using Outlook Application Object to create a new mail
Bhaskar
Please provide details of what you're actually trying to do and explain
whether you're working with the built-in editor or Word editor or both.
Sue Mosher
"Bachi" <Bachi> wrote in message
news:3D94785C-F205-47AC-8565-B4C68C05C4B5@microsoft.com...
> Thanks
> Bhaskar
Hi Mosher,
Actually i wrote a code in C# to generate a new mail message from outlook in
our application, and we are using the Word editor. when i click on the new
(new message) button from outlook i am able to see my signature.
But when i generate new message mail through code i am not able to get the
signature. i searched through msdn to get the properties and methods for
signature but i didnt get any revelant information.
Bhaskar
> > Sue Mosher
> > Thanks
> > Bhaskar
I still don't understand. Are you trying to add the signature to a message
or access the signature in an existing unsent message? Show the code that
creates or returns the message, please.
Sue Mosher
news:01357F02-B052-4708-BADB-35CEFAEF64C0@microsoft.com...
> Hi Mosher,
> in
> Thanks
> Bhaskar
>> > > Sue Mosher
> >>> > Thanks
> > > Bhaskar
Hi Sue,
I would like to ask you a question regarding accessing the signature in
outlook 2003.
Is is possible to deny users creating their own signature throug an add-in
or via exchange policy.
Is it also possible to disable using word editor and limiting the built-in
editor to limited number of characters? or do I need to write my own code to
take care of all this.
the reason for this is beause we want to unify signature and disclaimer for
all users and add them to thier new mail automatically.
thanks,
David
> > Sue Mosher
> > Hi Mosher,
> > in
> > Thanks
> > Bhaskar
> >> > >> Sue Mosher
> >> >> >> > Thanks
> >> > Bhaskar
So your question is really how to control what signature the user employs,
right? There are three ways to make Outlook to use a particular signature
with all accounts:
1) Set the NewSignature and ReplySignature string values in the
HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\11.0\Common\MailSettings
key to the name of the signature stored in the
%appdata%\Microsoft\Signatures folder. This applies the signature as a
policy setting, so the user won't be able to change the automatic signature
(and may also be blocked from some other features on the Tools | Options |
Mail Format dialog).
2) Same as #1, only set the NewSignature and ReplySignature string values in
the HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\Common\MailSettings
key. This applies the setting as a user preference.
3) Use a script like that at
http://www.outlookcode.com/codedetail.aspx?id=821 to apply the signature to
each account. This is the brute force method, available if you can't apply
SP2 for some reason.
Note that even if you mandate a signature with a Group Policy Object, the
user can still delete the signature from the message itself, and the savvy
user can edit the .rtf, .htm, and .txt files for that signature. That's why
if you really want a mandatory signature, you must do it on the server; see
http://www.slipstick.com/addins/content_control.asp for links to tools.
GPO can also be used to set the Outlook editor as the only editor. Outlook
has no feature for limiting the number of characters in a message body.
Sue Mosher
"Dave" <Dave> wrote in message
news:6957AF07-62C6-4C8F-9582-07B1C759226E@microsoft.com...
> Hi Sue,
> outlook 2003.
> to
> for
Thanks for your reply.
I am gonna try you suggestions en get get back to you if there are more
questions.
David
> with all accounts:
> > Sue Mosher
> > Hi Sue,
> > outlook 2003.
> > to
> > for
M Accessing ALL Outlook contact fields Outlook VBA and Custom Forms 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Accessing Hotmail accounts with Outlook 2016 Using Outlook 3
n2b Accessing Plain Text Draft Without Outlook Using Outlook 3
G Issues with accessing Outlook Contact Picture with VBA Outlook VBA and Custom Forms 4
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
mikecox Accessing Outlook on my Win7 desktop from Win8 laptop Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
J Outlook closes when accessing History in BCM BCM (Business Contact Manager) 4
L Outlook Forms-Accessing Outlook VBA and Custom Forms 1
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
V Outlook custom form - installing and accessing Outlook VBA and Custom Forms 1
A Accessing full contact forms Using Outlook 2
J Accessing calendar items for Resource Mailboxes Outlook VBA and Custom Forms 2
M Accessing ExpiryTime property Outlook VBA and Custom Forms 1
C Problem accessing events for folder "username" Server Threw Exception Using Outlook 1
A "Unable to display the folder" error when accessing Group mailbox Using Outlook 0
Commodore Accessing mail from multiple devices Using Outlook 1
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
R Accessing folder 'Other Contacts' Outlook VBA and Custom Forms 1
E Accessing a Form Region from an Inspector Outlook VBA and Custom Forms 3
D Accessing Global Address List details with VBA Outlook VBA and Custom Forms 1
K assistant accessing from her home computer BCM (Business Contact Manager) 2
C Accessing _RecipientControl1 (Assigned To) Outlook VBA and Custom Forms 2
A Daily hours of recurring/ multi-day appts, & accessing mult calend Outlook VBA and Custom Forms 2
R New users creating get page cannot be displayed when accessing OWA Exchange Server Administration 16
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
