How can i save the body as text file
  • Thread starter Thread starter Toon_24
Toon_24
I would like to save the body as a .txt file
can someone please help
thanks in advance
N2OLD2L
I found the answer allready.
N2OLD2L
> thanks in advance
> > N2OLD2L
T Is it possible to save email body without header? Outlook VBA and Custom Forms 6
R Unable to save complete email to File Explorer Using Outlook 2
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
