Combining data from two fields
  • Thread starter Thread starter JKR in VA
JKR in VA
I am using a message form in Outlook. I want the value of field "A" to equal
what is typed into "A", appended to what is typed into field "B".
In my trials, I cannot get the information typed into "A" to stay, it gets
removed and replaced by the data in "B".
Would someone please help me with this?
Thanks!!!!
Try using the CustomPropertyChange event, as demonstrated at
http://www.outlookcode.com/article.aspx?ID=38.
Sue Mosher
"JKR in VA" <JKR in VA> wrote in message
news:B85E904D-725F-4019-8B3B-6012662ACC07@microsoft.com...
> equal
> Thanks!!!!
Hi Sue,
Thank you for your help. This is beyond my ability level.
What I want to end up with is requiring the user of the form to fill out
either field "A" or field "B". I am using the text from these fields in the
subject line.
Is there a way with just the built in standard functions to achieve this?
> > Sue Mosher
> >equal
> > Thanks!!!!
I'm confused. The description in your latest message doesn't match what you
originally posted. Are you trying to do *both* validation and appending text
from one field to the value of another? Or are you taking the values of two
fields to create the value of a third?
FWIW, I have found over more than a decade of work, that VBScript behind a
custom form is not beyond anyone's ability. I would encourage you to read
through the examples and then ask specific questions if there's something
you don't understand.
Sue Mosher
"JKR in VA" <JKRinVA> wrote in message
news:FBDCDEF8-FD4C-43F4-B5A3-6C59973137F5@microsoft.com...
> Hi Sue,
> the
> subject line.
>> > > Sue Mosher
> > >equal
> > > gets
> >> > Thanks!!!!
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
RBLampert Combining PSTs Using Outlook 1
D Combining date and time into one field Outlook VBA and Custom Forms 2
mwh1962 combining pst & ost calendars & contacts with Office 365 Using Outlook 5
W combining outlook accounts Using Outlook 0
M How to set exchange calendar as default when combining with Internet calendar Using Outlook 2
D Outlook 2010 and combining multiple rules into one? Using Outlook 4
CWM330 Saving Data: Don't check certain folders Using Outlook 2
CWM330 Importing " Old Skool" Data Using Outlook 0
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
