How to get Selected Body message Text
  • Thread starter Thread starter pasteface method crashing outlook
P
I need to handle an event whenever we select something in mail body. Can
anyone say how to handle this event and how to get selected text.
I'm developing an outlook add-in in ATL COM(VC++)
Regards
Kiran. S
There is no such event in the Outlook object model. If you are using
WordMail you can get Inspector.WordEditor as a Word.Document object and use
the Word Object model for that. If you are using HTML then you would have to
use the IHTMLDocument object model.
"pasteface method crashing outlook"
<pastefacemethodcrashingoutlook> wrote in message
news:BAF45B97-8706-4AED-AE9B-9AE409C037F0@microsoft.com...
> Hi,
> Regards
> Kiran. S
Thanks Ken,
I tried Word Object Model and tried to capture the WordEditor of an mail
item. But inspector->get_WordEditor() is giving null pointer.
CComQIPtr<Outlook::_Inspector> spInspector;
CComPtr<MSWord::_Document> spWordDoc;
CComPtr<MSWord::Selection> spWordSelection;
CComPtr<MSWord::_Application> spWordApp;
spMailItem->get_GetInspector(&spInspector);
CComPtr<Outlook::_Application> spApp;
spInspector->get_EditorType(&editType);
BSTR str;
VARIANT_BOOL vTemp;
spInspector->IsWordMail(&vTemp);
if(vTemp == VARIANT_TRUE)
spInspector->get_WordEditor((IDispatch**)&spWordDoc);
spWordDoc->get_Application(&spWordApp);
spWordApp->get_Selection(&spWordSelection);
spWordSelection->get_Text(&str);
Please let me know if any issue found.
Regards
Kiran. S
> > Hi,
> > Regards
> > Kiran. S
Where are you calling that code?
I've seen, especially in Outlook 2007, that WordEditor is null up until the
first Inspector.Activate() event. For example it's null in
Inspectors.NewInspector() because you're only getting a weak object
reference at that point.
If there is no Inspector then obviously there can't be a WordEditor object
since there is no Inspector.
news:176F9A27-950A-4E6B-988E-ECE67B4CDB1B@microsoft.com...
> Thanks Ken,
> Code:
> BSTR str;
> VARIANT_BOOL vTemp;
> Regards
> Kiran. S
I'm call the code when we change mail item in main pane( BY handling
Command-Bar events). I'm able to get Inspector pointer but its WordEditor is
returning NULL. Using the below code to capture Inspector pointer.
CComPtr< Outlook::Selection>spSelection;
m_pExplorer->get_Selection(&spSelection);
BSTR strname;
if(spSelection)
CComPtr< IDispatch > spItem;
CComVariant vCount(1);
spSelection->Item(vCount,&spItem);
if(!spItem)
return;
ATLASSERT(spItem);
CComQIPtr< Outlook::_MailItem> spMailItem(spItem);
ATLASSERT(spMailItem);
fprintf(fileptr,"[WSforOutlookMailItemSearching]->spMailItem::Success\r\n");
fflush(fileptr);
- Kiran. S
> > Thanks Ken,
> > Code:
> > BSTR str;
> > VARIANT_BOOL vTemp;
> > Regards
> > Kiran. S
You would need to display the Inspector.
news:8990F45A-4C5F-493E-8826-2CA7078A281E@microsoft.com...
> is
> Code:
> BSTR strname;
> if(spSelection)
> if(!spItem)
> return;
> ATLASSERT(spItem);
> fflush(fileptr);
> - Kiran. S
can you tell me which event is needed to handle , when we select the text in
outlook 2007.
-Kiran.S
> > is
> > Code:
> > BSTR strname;
> > if(spSelection)
> > if(!spItem)
> > return;
> > ATLASSERT(spItem);
> > fflush(fileptr);
> > - Kiran. S
There is no event for that in the Outlook object model.
You'd have to open the item so it was being handled by WordMail, get
Inspector.WordEditor as a Word.Document object, then get the Parent property
of that as Word.Application and use the
Word.Application.WindowSelectionChange() event.
If the text was selected in the reading pane I don't know of a way to get an
event for that at all.
news:774C1A99-AEC8-4E82-BFB9-D150A67D2647@microsoft.com...
> in
> outlook 2007.
> -Kiran.S
R Reply with custom form & selected data from message body Outlook VBA and Custom Forms 3
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
L Hide Selected Email Address from Address Book Using Outlook 5
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
J Checkboxes when selected will appear in a textbox in Outlook 2016 Outlook VBA and Custom Forms 1
K How to reference the selected folder Outlook VBA and Custom Forms 1
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
G Autocomplete adds suspicious "@unknown.email" to selected contacts Using Outlook 1
B Macro to manually move selected emails to network folder Outlook VBA and Custom Forms 1
A Helping OL remember which calendars were selected Using Outlook 6
Diane Poremsky Save Selected Email Message as .msg File Using Outlook 11
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
mikolajek Random message selected after hard delete Using Outlook 4
Diane Poremsky Working with All Items in a Folder or Selected Items Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
A VBA to create meeting from template from a time slot selected in someone's calendar Outlook VBA and Custom Forms 5
Diane Poremsky Create Task or Appointment and Insert Selected Text Using Outlook 0
Yusufbodrum Highlighting selected mails in any folder Using Outlook 2
P Subject change on selected emails Outlook VBA and Custom Forms 14
C Autofill subject line in appointment from options selected in combobox Using Outlook 6
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
M Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
S Macro to print & move selected emails? Using Outlook 3
L Selected Contacts For E-Mails Using Outlook 19
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
L Outlook 2007 E-Mail From Selected Task Using Outlook 18
