Add-In - How to
  • Thread starter Thread starter Luis
L
Luis
Would like to code and deploy an Add-In for outlook. Where do I start reading
and/or studying about it. I have a macro that I would like to start executing
(one time) when someone start Outlook.
Thank you for guidance.
Luis
Start by reviewing the information at www.outlookcode.com.
There are books available for different levels of reader, you can also pick
up a book on Outlook development.
"Luis" <Luis> wrote in message
news:E5B2DA88-40F5-4A07-89DB-2F97579183BC@microsoft.com...
> reading
> executing
> Luis
J add a delay to VB that automatically prints PDF's Outlook VBA and Custom Forms 5
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 3
T Add Account Using Outlook 1
