Outlook2007 Email problem with automation
  • Thread starter Thread starter Dennis Rose
Dennis Rose
I am using automation in a VB5 program to send Emails using Outlook2007. If
I use the ".Send" mailitem the email is sent out Immediately.
If I use the ".Display" mailitem in my program, after I look over the Email
and then click the "Send" button on the Outlook display screen, the email is
placed in my outbox but does not get sent out. I have to exit my program and
then click "Outlook". When Outlook displays, I can see the Email in the
Outbox which will then automatically go out (without me having to click send
and receive).
I want the Email to immediately go out (when using the ".Display" mailitem
in my program) after clicking the "Send" button on the Outlook display
screen.
What do I need to do??
Do you immediately set the variable poiting to the message to Nothing?
What is the relevant snippet of your code?
Are you sending through SMTP or Exchange?
Dmitry Streblechenko (MVP)
"Dennis Rose" <DennisRose> wrote in message
news:ECB1DC9A-F9C9-4069-9EEC-9BB64CC56070@microsoft.com...
> If
> Email
> is
> and
> send
> and receive).
> screen.
Thanks for the reply!
I am sending thru SMTP.
This is my code:
Private Sub SendEmail()
Dim OutApp as Outlook.Application
Dim OutMail as Outlook.MailItem
If OutlookPresent = True Then
Set OutApp = CreateObject("Outlook.Application")
OutApp.Session.Logon
Set OutMail = OutApp.CreateItem(olMailItem)
With OutMail
> To = txtEMailAdr.Text
> CC = ""
> BCC = ""
> Subject = "Customer Follow-Up"
> SendUsingAccount = OutApp.Session.Accounts.Item(1)
> Display
On Error GoTo 0
Set OutMail = Nothing
Set OutApp = Nothing
MsgBox "Email Sent"
> >If
> > Email
> > is
> > and
> > send
> > and receive).
> > screen.
I forgot to include the ".Body = "Test email"" instruction but it is there.
> This is my code:
> With OutMail
> .To = txtEMailAdr.Text
> .CC = ""
> .BCC = ""
> .Subject = "Customer Follow-Up"
> .SendUsingAccount = OutApp.Session.Accounts.Item(1)
> .Display
> End With
> On Error GoTo 0
> MsgBox "Email Sent"
> End If
> End Sub
> > >If
> > > Email
> > > is
> > > and
> > > send
> > > and receive).
> > > screen.
Is Outlook running at the time your code is executed?
news:A90FA782-7663-4048-8533-DEB3880A4958@microsoft.com...
>> This is my code:
>> With OutMail
> > .CC = ""
> > .BCC = ""
> > .Display
> > End With
> > On Error GoTo 0
>> MsgBox "Email Sent"
> > End If
> > End Sub
> > > >Outlook2007.
> > > >If
> > > > Email
> > > > email
> > > > is
> > > > program
> > > > and
> > > > the
> > > > click
> > > > send
> > > > and receive).
> > > > mailitem
> > > > display
> > > > screen.
N How to add Dear & mail receipts name while reply to that mail in outlook2007 Outlook VBA and Custom Forms 1
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
Z Outlctl disabled (Outlook2007 SP2) Outlook VBA and Custom Forms 2
R Could i do this with ribbon(outlook2007)? Outlook VBA and Custom Forms 1
R About repurpose ribbonX of outlook2007? Outlook VBA and Custom Forms 3
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
Y How to record macros in Outlook2007? Outlook VBA and Custom Forms 1
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P anything new on the supposed shutdown of comcast.net email? Using Outlook 6
W frustrating trying to change email password Using Outlook 5
R File not found when sending email with attached pdf file Using Outlook 2
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
P Xfinity/Comcast email service stopping sometime in 2025 - warning Using Outlook 8
O Two identical email accounts in Offline Global Address List Using Outlook 2
H Spam email in Gmail not visible in Outlook Using Outlook 3
L Hide Selected Email Address from Address Book Using Outlook 5
Y QQ on Scheduled Delivery of an Email Using Outlook 0
T Replace Text in Email Subject Outlook VBA and Custom Forms 3
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
M Thunderbird email client - I wonder Using Outlook 1
D Outlook Desktop App Email Software Using Outlook 0
T Outlook 2010 Creating a email 'Group' in OL 2010 Using Outlook 2
T How to set Default FONT for Email composing ? Using Outlook 0
H Finding text in open email Outlook VBA and Custom Forms 12
A Opening a link from an email automatically Outlook VBA and Custom Forms 0
D Outlook 2021 New email reminder Using Outlook.com accounts in Outlook 1
Rupert Dragwater How do I remove an email ending with @gmail.com Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
F Graphics in email / Mac recipient garbled Using Outlook 0
