Setting appointment label
  • Thread starter Thread starter Paul
P
Paul
I'm using office 2003.
I'm using the code below to change the label for my appointments based on
the subject contents, but when I run the code not all the appointments are
changed to the assigned label. Some will stay white...
Any ideas anybody?
Cheers,
Paul
Sub Label()
Dim objOutlook As New Outlook.Application
Dim objNamespace As Outlook.NameSpace
Dim objFolder As Outlook.MAPIFolder
Dim objAppointement As Outlook.AppointmentItem
Dim objAttachment As Outlook.Attachment
Dim objNetwork As Object
Dim lngDeletedAppointements As Long
Dim lngCleanedAppointements As Long
Dim lngCleanedAttachments As Long
Dim blnRestart As Boolean
Dim intDateDiff As Integer
Set objOutlook = Outlook.Application
Set objNamespace = objOutlook.GetNamespace("MAPI")
Set objFolder =
objNamespace.GetFolderFromID("00000000AAAEAB88111BB14FB3930A1FFF7C2A9101000EF192502C04154AB66E62534AEC6E18002B0EF780E70000")
For Each objAppointement In objFolder.Items
DoEvents
If objAppointement.Subject = "x" Then
Call SetApptColorLabel(objAppointement, 1)
ElseIf objAppointement.Subject = "y" Then
Call SetApptColorLabel(objAppointement, 2)
ElseIf objAppointement.Subject = "r" Then
Call SetApptColorLabel(objAppointement, 3)
ElseIf objAppointement.Subject = "t" Then
Call SetApptColorLabel(objAppointement, 4)
ElseIf objAppointement.Subject = "g" Then
Call SetApptColorLabel(objAppointement, 5)
Sub SetApptColorLabel(objAppt As Object, _
intColor As Integer)
Const CdoPropSetID1 = "0220060000000000C000000000000046"
Const CdoAppt_Colors = "0x8214"
Dim objCDO As Object
Dim objMsg As Object
Dim colFields As Object
Dim objField As Object
Dim strMsg As String
Dim intAns As Integer
Set objCDO = CreateObject("MAPI.Session")
objCDO.Logon "", "", False, False
If Not objAppt.EntryID = "" Then
Set objMsg = objCDO.GetMessage(objAppt.EntryID, objAppt.Parent.StoreID)
Set colFields = objMsg.Fields
Set objField = colFields.Item(CdoAppt_Colors, CdoPropSetID1)
If objField Is Nothing Then
Err.Clear
Set objField = colFields.Add(CdoAppt_Colors, vbLong, intColor, CdoPropSetID1)
objField.Value = intColor
objMsg.Update True, True
strMsg = "You must save the appointment before you add a color label. " & _
"Do you want to save the appointment now?"
intAns = MsgBox(strMsg, vbYesNo + vbDefaultButton1, "Set Appointment Color
Label")
If intAns = vbYes Then
Call SetApptColorLabel(objAppt, intColor)
Set objAppt = Nothing
Set objMsg = Nothing
Set colFields = Nothing
Set objField = Nothing
objCDO.Logoff
Set objCDO = Nothing
Where is this code running? If it's in the Outlook VBA project you should
never use New to set an Outlook.Application object, use the intrinsic and
trusted Application object. If it's not running in Outlook then using New
set objOutlook, don't set it again.
Never hard code a folder or item EntryID. If this is the default Calendar
folder use objNamespace.GetDefaultFolder(olFolderCalendar).
Are you getting any errors? I could see problems arising from the constant
logging into and out of CDO sessions. You should do the CDO session creation
and login once and use a global or pass the CDO.Session object. CDO does
have some memory leaks when you do multiple login/logoff operations like
that.
I'd comment the error handler so errors will fire or I'd test for errors at
critical points so I could see what's going on, either that or step the code
and see what's happening.
"Paul" <Paul> wrote in message
news:8AB39441-5C1E-431C-9A3E-B359B9A338C0@microsoft.com...
> Hi,
> Any ideas anybody?
> Cheers,
> Paul
> Sub Label()
> Set objFolder =
> DoEvents
> End If
> Next
> End Sub
> On Error Resume Next
> Err.Clear
> CdoPropSetID1)
> Else
> End If
> Else
> _
> Label")
> Else
> Exit Sub
> End If
> End If
> objCDO.Logoff
> End Sub
K setting up appointment from to-do bar Using Outlook 1
T Removing time zone setting from an appointment / meeting: is it possible? Using Outlook 2
J Outlook Appointment recurrence setting Outlook VBA and Custom Forms 4
V Setting up Outlook 2021 on new computer Using Outlook 2
AlphonseG Outlook 365 Outlook Crashes on setting SaveSentMessageFolder Outlook VBA and Custom Forms 4
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
Jennifer Murphy Equations don't comply with style setting to left justify Using Outlook 0
J Setting default address book Using Outlook 0
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
Diane Poremsky Setting up an Outlook.com IMAP account Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
Diane Poremsky Adjusting Outlook's Zoom setting in Email Using Outlook 0
O Setting default format for composing/replying to emails Using Outlook 3
B Outlook Calendar/setting appointments Using Outlook 1
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
L Setting up my PA's Outlook Using Outlook 7
N "Instant Search" setting a default view Using Outlook 3
H SETTING UP A "NEW" NEVER HAD NEVER USED EMAIL ACCOUNT Using Outlook 9
K Setting Default Email Address for Meeting Replies Using Outlook 3
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
D Setting defult "Show a room list" Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
J Setting tabs in contacts / notes field Using Outlook 0
T Setting a Default Subject from a certain Signature Using Outlook 0
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
mikecox setting Default area code in Contacts Using Outlook 5
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
V View zoom setting changing Using Outlook 1
