XLS Import Issue With Source of Lead field
  • Thread starter Thread starter CheesePlant
C
CheesePlant
When I import a spreadsheet into BCM 2007 it displays the error "Field is
unknown or this field value is not settable."
This error is displayed because the 'Source of Lead' data in the spreadsheet
is not in the defined 'Source of Lead' list in BCM. I have thousands of
records and can not manually enter all the sources.
Is there anyway I can import the leads from the spreadsheet without having to
define the 'Source of Lead' list?
On 3/24/2010 8:13 AM, CheesePlant wrote:
> Hello,
> Thank you.
I'd add a column in the spreadsheet and populate it with one source.
Sounds like mapping of fields is not done correctly.
Do an export from BCM and use it as a guideline for creating an import
document.
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
Leonid S. Knyshov // SBS Expert wrote:
> > Hello,
> [quoted text clipped - 9 lines]
>> Thank you.
> document.
The mapping works fine. In the "Source of Lead" field inside BCM I created a
test Source and imported a test record it went in fine. Its as if I have to
manually create all the Sources inside BCM before it will import.
> >> Hello,
>>> Thank you.
> > document.
That is exactly correct.
BCM does an INSERT statement and apparently checks for validation to
existing sources. The likely reason for this is so you don't wind up
with a split records base just because someone made a typo on the source
field.
It should not be hard to have someone write you a bit of custom code to
generate such sources inside BCM programmatically.
I'll work on such a thing. Thanks for the idea.
Leonid S. Knyshov
Thank you, how do you put custom code into BCM? For now I've had to create a
custom field called "Sources". Its a bit of a messy nightmare.
> >>> Hello,
> [quoted text clipped - 11 lines]
> field.
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
C New pc, new outlook, is it possible to import auto-complete emailaddress Using Outlook 5
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
CWM330 Import Exchange Server Administration 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
DoctorJellybean Import accounts\files Using Outlook 1
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
Rupert Dragwater How to import contact list Using Outlook 15
C Import Outlook 2016 contacts into to: field Using Outlook 1
P Import an .ics file to a specific calendar Using Outlook 4
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
R ost file import Using Outlook 2
T Outlook Calendar 2016 import Excel Using Outlook 1
I Import Office theme .thmx Using Outlook 4
Diane Poremsky Batch Import Photos into Outlook Contacts Using Outlook 0
Diane Poremsky Can't import CSV or move Outlook items into EAS Accounts Using Outlook 0
Diane Poremsky How to Import Appointments into a Group Calendar Using Outlook 0
B Import Excel Text into Outlook Calender Using Outlook 4
M How to Import YES/NO Checkboxes? BCM (Business Contact Manager) 0
J Converted .ost to .pst: Want to Import and Reconnect with IMAP Email Account Using Outlook 2
GregS Import from Outlook.com .ost to IMAP .pst? Using Outlook 3
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
Diane Poremsky Import Images into the Active Directory Using Outlook 0
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
V Import from Outlook 2013 ost file? Using Outlook 2
ogodt Change Default contact form and import from Excel 2010 Using Outlook 1
A Does Outlook import Gmail Archive? Using Outlook 1
E PDF Import Using Outlook 1
B Problem with import Excel BCM (Business Contact Manager) 1
bhogesh How to import .htm saved mail to outlook Using Outlook 3
J Easy way to re-import Gmail folders/labels into Outlook? Using Outlook 9
J Opening/Archiving/Import/Export PST files Using Outlook 4
