Add Hyperlink in Email Body by VBA
  • Thread starter Thread starter K
K
K
Sub SETLINK()
ActiveSheet.Hyperlinks.Add Anchor:=Range("A78"), Address:= _
RECORDS.xlsx, _
TextToDisplay:="HERE"
Hi all, I want to add Hyperlink in Email Body by using above macro.
I just want to know that I have created above macro in excel but I
want to have same macro in outlook so what should I put in above code
where it say "ActiveSheet" and "Range("A78"). I assume it might be
"Obj.Body" or something but i want some friend to give me bit help.
This works for the active e-mail:
Dim Mail as Outlook.MailItem
Set Mail=Application.ActiveInspector.CurrentItem
Mail.HTMLBody="<a href='your link'>click me</a>"
Best regards
Michael Bauer
Am Thu, 23 Apr 2009 08:11:22 -0700 (PDT) schrieb K:
> Sub SETLINK()
> RECORDS.xlsx, _
> End Sub
A Add Hyperlink to Task Outlook VBA and Custom Forms 11
P Can't add a custom hyperlink to toolbar in OL 2010 Using Outlook 1
T Add Account Using Outlook 1
