Assign To and CC list while using Redemption.dll library
  • Thread starter Thread starter cGFyZXNo
C
cGFyZXNo
I could see that objSafeMailItem.To and objSafeMailItem.CC properties are
read only. Could any one tell me if there is any way to set added or is being
added recipients to To or CC list in below code:
' itm is selected Mail item object
Set objSafeMailItem = CreateObject("Redemption.SafeMailItem")
Set rpl = CreateObject("Redemption.SafeMailItem")
objSafeMailItem.Item = itm
rpl.Item = itm.Forward
' By default all recipients are getting added to To list. I want
some in CC list as well. Is it possible?
rpl.Recipients.Add (objSafeMailItem.Sender.Name)
For Each olkRecipient In objSafeMailItem.Recipients
rpl.Recipients.Add (olkRecipient.Name)
rpl.Recipients.ResolveAll
Paresh
It's the same process as when you add a Recipient using the Outlook object
model. Once you get back the SafeRecipient object from the call to
SafeRecipients.Add() you set the Type of the Recipient. You use one of the
OlMailRecipientType enum members: olTo, olCC or olBCC.
"paresh" <paresh> wrote in message
news:FAD5023E-1F8D-46F4-9302-C5BD850E15F0@microsoft.com...
> Hi,
> being
> Next
> Thanks,
> Paresh
Since only reading of the To property is blocked, SafeMailItem only
implements the read access. Since write access is not blocked, you can use
the original Outlook Object (itm)
Or you can declare objSafeMailItem as a generic Object rather than
Redemption.safeMailItem to force late binding: you won't get the compiler
warning and Redemption will be happy to forward the calls to the properties
and methods that it does not implement to the original object assigned to
the Item property.
Dmitry Streblechenko (MVP)
> Hi,
> being
> Next
> Thanks,
> Paresh
Dmitry,
I have changed the type of rpl to Object and below did trick. thanks.
rpl.To = objSafeMailItem.To
rpl.CC = objSafeMailItem.CC
But it is not resolving the recipients now. :-( Any idea?
Paresh
> the Item property.
> > Hi,
> > being
> > Next
> > Thanks,
> > Paresh
Ken, this looks great idea. Could you tell me how could I enum rpl.Recipients
and can set the type?
??? Enume rpl.Recipients
For Each olkRecipient In rpl.Recipients
?? how to set the type
thanks,
Paresh
> > Hi,
> > being
> > Next
> > Thanks,
> > Paresh
You can use the For...Each loop you show below or you can get the Count of
the original item's Recipients collection and use a standard For...Next
loop. It's like iterating any collection, not rocket science.
To assign the type is totally simple:
oRecip.Type = OlMailRecipientType.olTo ' or olCC or olBCC
news:E84F349A-0807-4619-A6A7-EE11EA8793CB@microsoft.com...
> rpl.Recipients
> Next
> Next
> thanks,
> Paresh
Thanks Ken, I did below:
olkRecipient.Type = OlMailRecipientType.olCC
Still it is adding it To list only all the recipients. Am I doing anything
wrong?
Paresh
> > rpl.Recipients
> > Next
> > Next
> > thanks,
> > Paresh
You are attempting to change the Type of the original recipients and hoping
they will be that Type when added to a new mail item as recipients, and it
just doesn't work that way.
Any recipient object added to a mail item will be olTo unless you explicitly
set its Type on the new Recipient object.
Set oRecip = rpl.Recipients.Add (olkRecipient.Name)
oRecip.Type = OlMailRecipientType.olCC
You of course would have to declare that oRecip object somewhere prior to
that loop.
news:54887605-1E4A-4C13-A974-6E30FEA21FA3@microsoft.com...
> Next
> wrong?
> Thanks,
> Paresh
Thanks Ken, it works absolutely fine. See my below code:
Set odRecip = olkRecipient
Set oRecip = rpl.Recipients.Add(olkRecipient.Name)
oRecip.Type = odRecip.Type
I have only one problem in resolving the email addresses that are outside
our domain. It resolves the our domain address perfectly but it can't if
email address in outside the domain. I think this is happening because I am
using Recipient.Name property. So suppose name="xxx yyy" and oririginal email
id = "xxxyyy@gmail.com" then it keeps "xxx yyy" in the recipients list and
not resoving to original email id.
Could you help me here.
Thanks for being there.
Paresh
> Next
> that loop.
> > Next
> > wrong?
> > Thanks,
> > Paresh
Ken, I have changes the Recipient.Name property to Recipient.Address and its
works perfect now.
> Next
> Paresh
> > Next
> > that loop.
> > > Next
> > > wrong?
> > > > Thanks,
> > > Paresh
The name will only resolve correctly for an entry in your GAL or your
Contacts folder. As you found, the Recipient.Address is more universal.
news:4FEBAA69-2174-416E-B4C6-C1CE0FFB1EFF@microsoft.com...
> Next
> am
> email
> Paresh
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
F How to assign a task to a public task folder? Using Outlook 1
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
soadfan assign category (VBA) Using Outlook 7
Diane Poremsky Assign one task to several people Using Outlook 0
Diane Poremsky Assign an Email Account to an Outlook Contact Using Outlook 0
E for Mac: Assign Task not available!? Using Outlook 1
A Assign a unique number to every message I send Using Outlook 0
Z assign unique number email Using Outlook 8
J Assign a signature by external or internal reciepents. Outlook VBA and Custom Forms 1
P VBA to assign category on calendar item does not work ?? why ?? Outlook VBA and Custom Forms 5
S assign task programmatically Outlook VBA and Custom Forms 2
C Cannot assign a task from a public folder? Outlook VBA and Custom Forms 4
C How to assign icon to a button in Outlook Add-in Outlook VBA and Custom Forms 1
F Inaccurate Contact List Using Outlook 4
T Create a group from a large To distribution list Using Outlook 3
G Contact list separates some entries that have identical characteristics Using Outlook 0
O Two identical email accounts in Offline Global Address List Using Outlook 2
Rupert Dragwater Contact list didn't download Using Outlook 9
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
D DB/Object/Record vs File/List/Range Terminology Outlook VBA and Custom Forms 0
farrissf Category list to pick from Outlook VBA and Custom Forms 4
S Inconsistent view of To-Do List Using Outlook 0
S Different views for To-Do List and To-Do Bar Using Outlook 0
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
K Daily Task List Minimized Cannot Display Using Outlook 5
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
Ken Pascoe Outlook Categories Quick List Using Outlook 0
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 5
C must select message to trigger safe list Using Outlook 3
V Pin a document to the "Attach file" Recent Documents list Using Outlook 0
