How to add colors to a view
  • Thread starter Thread starter anders.mikkelsen@carlsberg.dk
I whould like to use VBA to create a view in outlook 2003 and it works
fine until I get to the automatic color formatting. I cannot find any
method/properties to the view that has anything to do with colors.
Is it possible to add colors to a view, like "all items send to me is
blue" using VBA?
Regards
Anders
No in Outlook 2003, yes in Outlook 2007.
<anders.mikkelsen@carlsberg.dk> wrote in message
news:182ebefc-31e1-4626-87b7-5c8f4cc61f0d@z7g2000vbh.googlegroups.com...
> Hi
> blue" using VBA?
> Regards
> Anders
J add a delay to VB that automatically prints PDF's Outlook VBA and Custom Forms 5
J Add imap account issue Using Outlook 9
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 0
T Add Account Using Outlook 1
