VBA ikn Outlook - messages archived? (Enterprise vault)
Miel
I am writing some macros in Outllook, mostly for forwarding and replying to emails, but also for archiving. For this, I want my macro to check whether all items in a folder have been archived (archiving is being done by rule in Enterprise Vault and works fine). The aim is that 'empty' folders (meaning folders where all items have been archived) can be deleted.
I cannot find any command that makes my macro check the items in a folder if they have been archived or not...
All information or help will be appreciated.
Does Enterprise Vault set a property identifying the item as having been archived? You'll need some way to know if the item was archived and once you test for that property your code will know whether to keep or delete.
You might want to post this in the MSDN Outlook Programming forum - http://social.msdn.microsoft.com/Forums/office/en-US/home?forum=outlookdev - more developers hang out there.
E Need to digitally sign macro but VBA\Outlook crash Outlook VBA and Custom Forms 1
