VBA problem in new install
colblip
I have code which has worked great on 3 different computers over the years. Now I am getting an error message on my latest computer. The code is for a macro that will select a specific contact view (I've got several different views and the project has several subs to view each of these). I am getting a compile error with the message - can't find project or library. Any help would be appreciated.
Sub GetViewChurch()
'Selects a new view
Dim myOlExp As Outlook.Explorer
Dim objName As NameSpace
Dim objViews As Views
Dim objView As View
Dim myolapp As Outlook.Application
Dim mynamespace As NameSpace
Set myolapp = CreateObject("Outlook.Application")
Set mynamespace = myolapp.GetNamespace("MAPI")
Set myolapp.ActiveExplorer.CurrentFolder = mynamespace.GetDefaultFolder(olFolderContacts)
Set objName = olApp.GetNamespace("MAPI")
Set myOlExp = olApp.ActiveExplorer
Set myFolder = objName.GetDefaultFolder(olFolderContacts) <<<<<<========= error here
Set myExplorer = myFolder.GetExplorer
'myExplorer.Display
Set objViews = objName.GetDefaultFolder(olFolderContacts).Views
myOlExp.CurrentView = "Church"
Diane,I don't expect you to remember, but you helped me create this code, 7 or 8 yrs ago. :-)I finally got this working by copying my existing vbaproject.otm file (along with a number of others - nk2, etc.) to the new computer and fooling around with the digital signatures. For future reference, how does one 'set references...'?Thanks.
So a digital signature caused problems? I'm surprised Outlook allowed you to open the VBE without telling you the signature was bad. (I'm getting that all the time lately after signing a macro then testing others and forgetting to resign it.)
This code shouldn't need references set because it only uses the outlook library and the reference to that should be set by default.
To check or set references - in the VB Editor, go to Tools, References. VBA, Outlook library should be selected by default.
