From column changes when message is read
jknoxville
Outlook 2011 for Mac
Using outlook 2011 for mac:
The "From" column changes after I highlight it when the message is of the form:
john doe <different_name@foo.com
Initially the From column has "john doe"...until I highlight the message and then the name changes to "different_name"........Can I keep it "john doe"?
F Outlook Data File Column Empty Using Outlook 3
T Combine colums to an from into one column Using Outlook 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
ad24rouse Column Width of To-Do Bar Using Outlook 5
T Can't reposition "Flag Status" column Using Outlook 0
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Tasks - Is there a postponed date column? Using Outlook 7
N Column view fonts Using Outlook 4
O How to display senders email address (column) Using Outlook 1
D Column for To Email Address Using Outlook 0
H "Advanced find: column for full folder path? Using Outlook 1
A Can't add a column called "name" to Inbox? Using Outlook 1
D Email Icon Column Using Outlook 2
H SQL update column BCM (Business Contact Manager) 0
C How to copy same text header to multiple emails with custom text column Using Outlook 10
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
R Renaming Column Heading in Contacts view Using Outlook 6
T Column Header Keyboard Shortcut Available? Using Outlook 5
H Calendar column of time without date? Using Outlook 0
K Sent folder only shows "From", not "To" column Using Outlook 1
S Outlook 2007 Sort Column Shading Using Outlook 1
A How to replace column title in address book Using Outlook 1
B Populating Additional Outlook Column with Date \ Time Using Outlook 0
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
S Custom Yes/No column field Outlook VBA and Custom Forms 2
K Who made changes to a shared contact Using Outlook 3
D Outlook 365 Recent changes to "Undeliverable" automated replies? Using Outlook 2
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
M Outlook changes the "Modified" field when moving/copying a Contact. Using Outlook 0
V Latest Changes to form not appearing for some users Outlook VBA and Custom Forms 3
T How to deal with Upcoming GMAIL changes Using Outlook 2
O Unable to make changes to an existing Calendar entry Using Outlook 11
C Tracking Calendar Changes? Using Outlook 1
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
A Form style totally changes Outlook VBA and Custom Forms 2
