Cached mode additional mailboxes
Hi.
We have a remote office with Outlook 2003 configured to access a 2003 Exchange server in our head office, via a VPN.
Outlook is set for cached mode and this works fine for single mailboxes, with the associated outlook.ost file being stored in a user's profile. However, if we set Outlook to open an addition mailbox (via Advanced tab in More Settings...), then as far as I can tell, it is not cached in an ost file and consequently, is very slow to access.
Can anyone confirm if an additional mailbox can be cached and if so, how to do it?
Thanks for that. At least I know now, although in the short term, we will have to live with Outlook 2003.
U Trouble with Cached Exchange Mode not fully implementing Using Outlook 3
A Outlook 2016 in Cached Mode Using Outlook 1
N Shared mailbox in cached mode Using Outlook 0
L Outlook Office 365 cached mode crashing Using Outlook 0
J Cached mode no longer works with NTLM authentication Exchange Server Administration 0
R Microsoft Outlook 2010 - Non Cached Mode Using Outlook 0
B Configure Outlook so Exchange uses cached mode but new items are by default saved to Outlook.com Using Outlook 1
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
N Email Stuck in Outbox - Cached Mode - Roaming Profile Using Outlook 2
K Outlook Cached Mode - can't create rules to move email to another mailbox Using Outlook 2
W disabled cached mode, but Outlook still using OST Using Outlook 2
P Migrate profile - cached mode setting Using Outlook 2
S Unable to enumerate Mailboxes in NON Cached Mode (if more than 2) Outlook VBA and Custom Forms 8
L how to set downloaded cached emails Using Outlook 5
P Where are the cached emails stored? Using Outlook.com accounts in Outlook 2
R Mailto link inside Outlook 2010 being cached? Using Outlook 1
J Outlook, Word, Access crash unless run in Admin mode - time dependent it seems Using Outlook 10
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
F "This action is not available in the current mode" Using Outlook 0
C Outlook 2016 Username Not Working in Scheduling Assistant (Cache Mode) Using Outlook 0
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
Diane Poremsky Say No! to Compatibility Mode Using Outlook 0
oliv- "Online mode with Exchange server" vs "online" Exchange Server Administration 2
Diane Poremsky Outlook Only Starts in Safe Mode? Using Outlook 0
P Outlook in safe mode Using Outlook 2
TMok Outlook 2010 nop responds after I resumed the Wins8 from sleep mode Using Outlook 0
J BCM Crashing with Add-in Enabled in User Mode BCM (Business Contact Manager) 2
R Outlook Cache Mode Terminalserver disable through Registry Using Outlook 1
G Why won't VBA see a copied calendar in cache mode anymore? Outlook VBA and Custom Forms 20
Jennifer Murphy Sync RSS feed message after Safe Mode Using Outlook 3
K Following Several Power Cuts Can Only work in Safe Mode Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
M Outlook 2010 slowness in cache mode Using Outlook 3
L Macro mode Using Outlook 2
R "business contact manager logon failure server is in single user mode" - HELP! BCM (Business Contact Manager) 4
T passwords in outlook 2000(in XP Virtual PC mode) under Windows 7 Professional Using Outlook 6
S Outlook 2010 Terminalserver Cache Mode Instant Search Using Outlook 4
D Event on connection mode change? Outlook VBA and Custom Forms 2
P How to know Outlook is being started in Offline mode? Outlook VBA and Custom Forms 2
E BCM instalation in terminal services mode BCM (Business Contact Manager) 1
Q Otlk 2007 does not block when in "always prompt for..." mode Outlook VBA and Custom Forms 2
T Code to import address book in automatic mode Outlook VBA and Custom Forms 1
T STA mode Error Outlook VBA and Custom Forms 1
S Correct way to Identify is Mail is opened in Edit Mode Outlook VBA and Custom Forms 1
A outlook cache mode Outlook VBA and Custom Forms 1
W Inserting Additional Email Address Outlook VBA and Custom Forms 4
