Button for Send/Received for a specific account
Commodore
Outlook 2021 64 bit
Is it possible to create a toolbar button (in Outlook 2007) that would execute Send/Receive on one specific mail account only? I have send/receive groups, and the pull-down button for all accounts from the toolbar, but that involves some menu-wading. :)
This code works on send/receive groups, not specific accounts - replace 1 in mySyncObjects(1) with the group #
Public Sub SendReceiveGroup()
  Dim mySyncObjects As Outlook.SyncObjects
   Dim syc As Outlook.SyncObject
  Set mySyncObjects = Application.GetNamespace("MAPI").SyncObjects
       Set syc = mySyncObjects(1)
       syc.Start
I suppose a workaround is then to also create a send/receive group that only includes one account.
J Send and Receive Button - only check default account? Using Outlook 1
A custom send button Outlook VBA and Custom Forms 3
H Preventing the Send button from being clicked on an Outlook Form Outlook VBA and Custom Forms 1
S Create a custom "Send" Button Outlook VBA and Custom Forms 3
M button to send and print emails Using Outlook 26
M Programatically click the Send button. Outlook VBA and Custom Forms 5
N modify New mesage SEND button Outlook VBA and Custom Forms 1
B Customized Send button Outlook VBA and Custom Forms 5
G Outlook 2007 Meeting Item Send Button Outlook VBA and Custom Forms 10
D Button beside send, but not beside reply Outlook VBA and Custom Forms 2
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
A adding a custom send button? Outlook VBA and Custom Forms 1
C Outlook 365 What happened to the "Today" button? Using Outlook 13
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
B Please remind me how I added this message button Outlook VBA and Custom Forms 0
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 7
jehan2256 "History" button in Business Contact Manager Using Outlook 1
L "Insert Pictures" Button-Wrong Folder Using Outlook 5
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J "Contact" button in Journal entry Using Outlook 1
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
E Can't accept or decline task (no button appears) Using Outlook 2
Witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
A ScanPST finding errors but no Repair button Using Outlook 2
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
