How to forward a message and delay sending for up to 30 days
markymark
I'm using Outlook 2010 and need to do the following.
I receive email from someone with certain words in subject and I need to forward it to someone else and defer sending it it by 30/45 days.
Is this possible? I know there is options for defering delivery up to 120 minutes or delay delivery when doing it manually but need a rule to this automatically.
Start with this script:
Run a Script Rule: Change Subject then Forward Message
and use something like this to the deferral - where 45 is the # of days you want to defer it.
SendAt = DateSerial(Year(Now), Month(Now), Day(Now)) + 45
myForward.DeferredDeliveryTime = SendAt
decimals. now + .25 = 6 hours from now.
For 20 minutes, use
sendat = Now() + 0.01388
This calculates the date and adds 45 days - the message sends at midnight.
BTW, if you want to delay mail up to 120 minutes, you can use a rule to defer delivery. In rules wizard choose 'apply on messages i send' and use the defer delivery action. To hold more than 2 hours you need to set the defer delivery field either manually or using a macro.
I knew about the outlook rule to defer but it doesn't do exactly what I want, thanks for your advice and i'll give the 'minutes' code a try
cheers
Barry
I have tried this for forwarding with a delay of 20 minutes, the subject changes but I don't receive the forwarded mail, have I missed something or got code in the wrong order? as you can probably tell I'm new to this -
Sub ChangeSubjectForward(Item As Outlook.MailItem)
Item.Subject = "Forwared to FCI"
Item.Save
Set myForward = Item.Forward
myForward.Recipients.Add barry.wardill@*********.co.uk
SendAt = Now() + 0.01388
Is it in the outbox? (If it looks like a draft, an addin is marking the mail read when you open the folder. )
Yeah, the time calc is in the wrong order and you need either .display or .send. I like to use .display during testing so i can see when the messages look like without sending them. Change to .send when you are satisfied it works good.
Item.Save
myforward.display ' use display to test
Item.Save
that works a treat, thank you...............one thing I had missed off though was the quotes around my recipient
Thanks again for your help
Cheers
Barry
J Forward Message after editing attachments and include edited attachments Using Outlook 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D Forward message to address from subject Outlook VBA and Custom Forms 1
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
