Outlook will not send from home location
Rayddd
Outlook 2013 64 bit
I have a laptop running Windows 8.1. I am using Outlook 2013. I have my work email on Outlook on this computer. At work it works perfectly ( wifi ) When I am home Outlook receives emails fine but will not send any emails.
The error message I get is -- Outlook cannot connect to your outgoing (SMTP) server
I am using a Apple airport extreme router. I tried using a cat5 cable to connect direct to modem and it still will not send.
Other people who drop by using Outlook on ny wifi do not have the problem I am having. ATT is my ISP.
Any ideas?
Thanks Ray
Rayddd
Outlook 2013 64 bit
I just noticed at the bottom that it says account is working offline- how do I get it to work online?
Rayddd
Outlook 2013 64 bit
Thank you for your response- I tried the things you suggested - same problem- it still says I am working offline- I am still receiving emails- How do I get it back to working online?
Ray
What outgoing port are you using ? ATT may be blocking port 25. To check, go to File, Account Settings, double click on the account, then More Settings - Advanced tab.
Rayddd
Outlook 2013 64 bit
It is set to port 25- what I should I change it to?
Thanks! Ray
Standard SMTP ports are 465 with SSL enabled and 587 with TLS enabled. I'd try them - if they don't work, do you know who hosts the email? Does work run their own server or have someone host it?
M Outlook 2007 cant send email with vista Home Premium Using Outlook 8
F Send As a Gmail account via outlook Web Using Outlook 3
M Can't send email in outlook.com Using Outlook 9
R Can't send messages to groups in Outlook Using Outlook 2
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
E How to send automatic emails in outlook 2010 Using Outlook 1
P Send mails by Gmail not shown in outlook Using Outlook 5
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
T Can't send email through connected account (outlook.live.com) - goes to Drafts folder Using Outlook.com accounts in Outlook 3
Tim King Send mail from MSWord through Outlook Using Outlook 3
RalphG101 No indication of attachment, when selecting file, send to outlook. Using Outlook 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
K Outlook send emails without attachment to a list Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
S Send email from excel based on a condition (outlook 2007) Outlook VBA and Custom Forms 1
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
E Microsoft Office Outlook 2007 Send Error Using Outlook 11
O How to send outlook meeting request as attachment Using Outlook 3
D Outlook 2010 hangs during message send/receive Using Outlook 2
S Outlook 2010 won't send on Windows 8 Using Outlook 2
V Outlook 2010 – Send email based on categories Using Outlook 2
D Outlook VBA to open Excel attachment and send recipient's email address to a workbook cell? Using Outlook 4
S Can't send messages using Outlook 2007 from a business email Using Outlook 3
H Preventing the Send button from being clicked on an Outlook Form Outlook VBA and Custom Forms 1
C outlook 2013-how do i send email to myself? Using Outlook 1
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
M Outlook wont send emails but receives Using Outlook 1
R Outlook 2010 Send from other email address uses account address instead Using Outlook 1
J Outlook 2007 Error sharing Calendar: Error while preparing to send sharing message Using Outlook.com accounts in Outlook 2
