Reoccuring appointment issues when exporting Calendar to Excel
dip324
At work we use our outlook calendars to track and analyze time. Several people (but not all) are having two issues with the export:
1. We have a reoccuring event called Work Hours which obviously displays how many hours people worked on that day. When the calendar is exported, there are extra Work Hours events for the weekend in Excel that are not indicated in the calendar (no one works weekends).
2. If the time of a reoccuring event is modified, that event will not export to excel.
Thank you for your help,
Sincerely,
Deanne
Exceptions should export - unless the exception was erased. (Exceptions are easy reset.)
Is there any thing about the weekend events that export that might give us a clue? Is there something similar in the ones that include weekends and ones that don't?
The only pattern I can find is that it copies the Work Hours from Mon-Fri and carries it over to the weekend. On the reoccuring section of the event, Sat and Sun are not checked. No one has work hours for the weekend so they are never on there. I checked the 'Work Hours' Option in Outlook under File--> Options --> Work Time and only the work days are selected.
Deanne
The exceptions also are visible on the calendar (not erased), it's just they are not there when it's exported.
Y Q's on Appointment Reminders Using Outlook 2
B Linking contact to an Appointment Using Outlook 1
O Calendar - appointment templates and categories Using Outlook 1
W Appointment userproperties disappear Outlook VBA and Custom Forms 4
F Appointment Show All Fields Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
W Appointment occurrences change the location property Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
A Day view - print appointment details Using Outlook 1
R Recover Deleted Appointment in Calendar Using Outlook 0
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
S Appointment colour categories disappear Using Outlook 4
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Create Task or Appointment and Insert Selected Text Using Outlook 0
Pierce007 Maps/location in making an appointment Using Outlook 2
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Create Appointment From Email Automatically Using Outlook 0
P Appointment times are off by one minute Using Outlook 1
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
Diane Poremsky Create an Appointment Diary Using Outlook 0
