Script to Macro in Module
LMS
I found these two different ways to have a commandbutton in a contact run a code from the script that runs a macro from a module. Do either if these do it?
sub CommandButton1_click
call module1.macroname()
end sub
macroname
end sub
The macroname only version is the shorthand version - using call is optional. Using the module name eliminates ambiguous names - if you happen to have 2 with the same name, it finds the correct one. Either should work fine.
I just did
sub CommandButton5_click
call module7.E_Mails_From_Lou_Stoler_and_Catch_Ups()
end sub
and there is error "object module7 required"
and then I did:
end sub
and there errro is "type mismatch E_Mails_From_Lou_Stoler_and_Catch_Ups"
Any way to fix these?
end sub
Same errror "type mismatch E_Mails_From_Lou_Stoler_and_Catch_Ups"
type mismatch means there is something that doesn't match - you're asking for a string when it should be a value or something. Does the macro you are calling work fine if you run it on its own?
Yes it works fine....i open up the contact, go to macros, click on it, and run it and it does it....this is a macro code you gave me that creates the emai to the contact using a template....and the macro correlates to a userform so when I run the macro, it opens up the combobox from the related userform....
so the key is to create the commandbotton in the contact form thru the script so it runs that macro which opens up the combobox from the related useform...
Anything else to upgrade ??
OK....so is there a way that when I put the macro on the quck tool bar of the contact as a part of the form, can I create a commandbotton in a scipt or some other way that when I click on the commandbotton it runs the button from the quck tool bar?
And also, instead of using the macro goes to the userfrom, I typed the macro name which is just single macro that creates the email per the template....and it is the same error....
Where do i put it please and is it another macro or do i add the commandbutton click to it somehow and put in the script?
udate please??? I created that macro you just showed me....and when i run that macro, it runs the macroname I put in.....but how do I put that macro in the script so there is a commandbutton to it? I tried it per the standart commandbotton_click thing, and same error re not recognizing the macro
Thanks much....look forward to it being done!!! PS, sent you the codes in a word document.
Any update from the Smart Woman???? I need it!!! :):)
I found a way to create a code in the Outlook Session as follows and when I run it, it runs the macro of the macro name.
Public Sub runthis()
macroname
Then in the Script area of the Contact form, I added the following code and CommandButton6 to the form, and when I click on the CommandButton, it runs the macroname.
Sub CommandButton6_Click
Set myOlApp = CreateObject("Outlook.Application")
myOlApp.runthis
Then when I created the same things as second way with runthis1 with a different macroname and a commandbutton 7, when I run the contact from it shows the commandbuttons and the commandbotton7 runs the macro related to the runthis1
But the problem is when I publish this form, and create a new contact from the form, the new contact does not show the commandbutton7 for some reason....
So it seems I found the way to do it, but it is not saving the second commandbutton7 in the contact I create, even though when I click on a new contact to create, both commandbuttons show up, but the commandbutton7 does not save in the contact I create.
Can we fix this?
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
E New Macro/Script needed Using Outlook 5
R Script for simplifying spam control Outlook VBA and Custom Forms 7
