VB Script Help
Rakesh
Outlook 2013 64 bit
Hi All, I am writing a VB script which fetches mails from my Outlook to excel.But the problem which I am facing is I have multiple mailboxes eg. A,B,C. What I need is to fetch the mails from specific mailbox let say B.But when I am executing the script it is fetching mails from the mailbox A which is not required.I have not prioritize the mailboxes in my code.Can somebody please explain the way to fetch mails from a specific mailbox.
each mailbox should have an associated email address ( eg mailbox 1 being only emails to emailaddress1@domainname.com )...
Under the condition you are using VB SCRIPT vs VBA you might also try something like this...
Dim objOutlook
Dim objNamespace
Dim objMailbox
Set objOutlook = WScript.CreateObject("Outlook.Application")
Set objNamespace = objOutlook.GetNamespace("MAPI")
Set objMailbox = objNamespace.Folders("[EMAIL="emailaddress1@domainname.com"]emailaddress1@domainname.com[/EMAIL]") 'where the email address corresponds to the mailbox you want to retrieve the mail items for
You could then retrieve any email folders for that mailbox... for instance this would retrieve the inbox for the previously retrieved mailbox.
Dim objInbox
Set objInbox = objMailbox.Folders("Inbox")
D Script help - retain forwarded email body & location of script Outlook VBA and Custom Forms 5
R Script for simplifying spam control Outlook VBA and Custom Forms 7
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
