How much data will Outlook hold
JCR
Hi everyone, I have a question on the 2003 or 2010 or 2013 version of Outlook, How much data will Outlook hold, last time I stopped using Outlook because after about 15k emails or contacts the data PST file crashed and was corrupted and I lost everything. At that point I stopped using Outlook and I have been using Gmail accounts not happy about it but atleast it does not crash or delete my large file of Emails and Contacts.... Has MS finally improved, corrected and updated the Outlook and which version ??? can someone let me know please.
What version did you use that crashed at 15K? Really, really early ones had "small table" support and topped out at 15K per folder, but by Outlook 2002, a new pst could hold up to 65000 items per folder, 1.8 GB total size. If you used old pst in Outlook 2002 and didn't update to large table support, it stopped at 15k.
Beginning with Outlook 2003, you can use Unicode pst files and they hold a minimum of 20 GB by default. Each folder can hold unlimited data.
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
B Calendar shows too much info by default Using Outlook 0
L As much as I like Sperry's Outlook Utils Using Outlook 2
E OWA phones home too much? Exchange Server Administration 1
M Rules - daily status (email) doesn't change much daily, save 1 per week how? Using Outlook 1
CWM330 Saving Data: Don't check certain folders Using Outlook 2
CWM330 Importing " Old Skool" Data Using Outlook 0
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
