Add sender to distribution list?
Errol
Just a simple thing I need to do. Add a sender direct to a distribution list without having to filter it through all the rest of my addresses. Seems I can't do this? Any solutions? Can't believe it is designed to make my life miserable.
You can type the name or email address in the Members field. Click Add > from outlook contacts > then type (or paste) the address in the field.
In other words there is no way around it. I have to manually add each contact onto the distribution list.
There is no shortcut that you can use to add a contact to a dl. Ie, like right click on person's contact, choose Add to DL > and see a list of DLs.
But, you don't need to pick and choose from the address book or type addresses in one at a time either. If you have a list of addresses, either semicolon delimited or one address per line, you can paste the entire list in the members field.
K add an email to a business contact without linking/tracking sender BCM (Business Contact Manager) 0
R vba rule exception "except with specific words in the sender's add Outlook VBA and Custom Forms 2
T Add Account Using Outlook 1
