VBS Script: How to execute in Outlook
johnsmith464646
I am trying to export emails from outlook inbox, and I found the following VBS Script:
http://pastebin.com/juEPKaNW
I don't know much about how VBS scripts work. Can someone help direct me in the proper direction to execute this script?
Larry, thank you very much. I have been spending quite a bit of time trying to find this info. Thank!
Diane, I tried it out and it worked beautifully. I didn't realize that you wrote those articles too. Thanks for that.
Do any of those scripts for a one step export that includes subfolders?
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
S the folder condition is necessary in Outloook VBS Outlook VBA and Custom Forms 8
T Trying to start Outlook from VBA or VBS not working. Outlook VBA and Custom Forms 4
R Script for simplifying spam control Outlook VBA and Custom Forms 7
