ShowCategoriesDialog for a shared mailbox?
Jack Farnan
Exchange Server 2010
Hi All,
Im very new so bear with me please.!!:)
I have a macro that pops up before I send a message to remind me to place it in a category (that I got online) as below.
'Categorize Sent Items
'Place in ThisOutlookSession
If TypeOf Item Is Outlook.MailItem And Len(Item.Categories) = 0 Then
Set Item = Application.ActiveInspector.CurrentItem
Item.ShowCategoriesDialog
This works fine for me personal mailbox but doesn't when replying via the shared mailbox I only see my own personal categories and not that of the shared mailbox. Is it possible to select from the shared mailbox categories?
Thanks in advance
Jack
I need your help to design a outlook VBA for the below requirement.
My Team uses the generic mailbox on a daily basis with emails flowing at a count of 200-300 in a day. We usually categorize the emails based on the followup or alpha assigned to the members. My questions is we currently track the email productivity manually in an excel spreadsheet as and when an email is assigned to a category. I would want a macro which will ease out this process. Where we can just run the macro at the end of the day to extract the information of the count of the emails assigned to each category with an added details like Sender, Reply, Reply all or forward action on the email.
Thanks in advance....
Suviesh
See http://www.slipstick.com/developer/vba-copy-outlook-email-excel-workbook/ for a basic macro - you probably won't need the stuff between these lines:
sText = olItem.Body
xlSheet.Range("B" & rCount) = vText
you'd use something like
xlSheet.Range("B" & rCount) = oitem.sendername
xlSheet.Range("c" & rCount) = oitem.whatever
and so on.
I'll try and make time tomorrow to put something together.
P ShowCategoriesDialog for multiple inbox items Outlook VBA and Custom Forms 5
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
K Who made changes to a shared contact Using Outlook 4
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
S Outlook 365 Shared mailbox contact group member numbers not matching Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
peterbata Shared Tasks Outlook for Mac Using Outlook 5
N Having Shared Calendar shift to Current day Using Outlook 0
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
M Outlook 365 Searching all shared calendars Outlook VBA and Custom Forms 4
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
A New email notification on shared mailbox Outlook VBA and Custom Forms 0
N Shared mailbox in cached mode Using Outlook 0
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
M how to speed up search of shared contacts Using Outlook 0
S Recovering permanently deleted folder from shared mailbox Using Outlook 1
S How to extract mail items from multiple folders and shared mailboxes? Outlook VBA and Custom Forms 0
