Copy or move contacts into BCM?
JimR
I got Office 2013 installed (what a terribly boring look it has!) and installed BCM. Everything seems to work and now I am starting the process of getting a few hundred contacts into BCM.
I am confused about the copy/move concept, it seems that Outlook contacts and BCM contacts are in different places? What are the pros and cons of copy versus move? I want to setup my business contacts in a way that automatically gathers all communications (mails, meetings etc.) into BCM.
thanks
JimR
Hi Jim,
Not sure why no one has replied to your query.
I am a newbie, but can report that I imported a 15,000 contact database very simply. I hasten to add that I did carry out a few experiments first!
Having done that I linked my emails going back several years and they all attache to contacts.
Best regards
Chris
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
C Copy from one Profile to another Using Outlook 0
