Other peoples calendars going on the left
Halesowenmum
I use Outlook 2007 at work on Windows XP. Usually when I select Open Other User's Calendar my calendar stays on the left and the other ones stack up on the right. But as of yesterday the other people's calendars, if I select them, show up on the bloomin' left! It properly confused me yesterday.
Is there any way to stop it doing that???? Don't know why it started in the first place :-).
P Outlook 2013 not showing little colored square as to peoples availability Using Outlook 5
N Duplicate Driver Routes, Fixed by Synchronizing Calendars Between the Two Accounts Using Outlook 1
oasisoutdoorproducts "Syncing Calendars with Unexpected Companions". Using Outlook 1
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 3
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
N Outlook 365 How to show all calendars at startup? Outlook VBA and Custom Forms 0
P Syncing Outlook & iPhone Calendars Using Outlook 4
J Multiple calendars Using Outlook 0
Graham Hyman Outlook 2016 Internet Calendars appearing as deleted Using Outlook 4
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
M Outlook 365 Searching all shared calendars Outlook VBA and Custom Forms 4
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
B Sharing Outlook calendars gone wrong Using Outlook 0
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
D Sharing calendars Exchange Server Administration 1
K Can VBA intervene when updating Internet Calendars? Outlook VBA and Custom Forms 5
L Calendars in Outlook 2016 Using Outlook 0
A Helping OL remember which calendars were selected Using Outlook 6
Diane Poremsky New in Office 365 and Outlook.com: Interesting Calendars Using Outlook 0
Diane Poremsky Combine and Print Multiple Outlook Calendars Using Outlook 0
Jeanne Goodman Create Printout from Multiple Shared Calendars Outlook VBA and Custom Forms 8
Diane Poremsky Publishing Calendars on the Internet or an Intranet Using Outlook 0
Diane Poremsky Select Multiple Calendars in Outlook Using Outlook 0
Diane Poremsky Sharing Outlook.com Calendars Using Outlook 0
C Merge two archive calendars Using Outlook 1
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
M Reminders or Notifications for Internet Calendars Using Outlook 1
Diane Poremsky Print Monthly or Work Week Calendars Using Outlook 0
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
M Un-needed Calendars Using Outlook 1
R Automating from excel into shared Calendars Using Outlook 1
M Not All Outlook.com Calendars Showing in Outlook.com Using Outlook.com accounts in Outlook 18
T populating multiple calendars without invites Using Outlook 1
