Spacebar Not Scrolling Down
BradD
Outlook 2013 64 bit
In Outlook 2013 on Windows I use the spacebar key to scroll down a page in the message window. Then yesterday I pressed the spacebar key several times quickly and a dialog opened and closed in a split second. Now the spacebar no longer scrolls down. How do I get the old behavior back?
You don't know what the dialog was? There is a setting in reading pane options to read using the space bar, but if it was enabled it shouldn't be disabled on its own. Check the setting in View tab, reading pane, options.
Sent from my iPad using Tapatalk
The spacebar works in the Reading Pane. It stopped working in the Message window. The dialog closed too quickly for me to see any text.
I have restarted Outlook and rebooted Windows but the problem's still there.
Rupert Dragwater Scrolling through Directories hesitates Using Outlook 1
U No scrolling in note field of contact record Using Outlook 1
J Scrolling in a email message Using Outlook 1
B Outlook Calendar not coming down from cloud Using Outlook 2
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
O Addins slowing me down? Using Outlook 2
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
J blue down arrow Using Outlook 1
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
P Field in Forms displayed depending on the Item chosen from drop-down-list BCM (Business Contact Manager) 1
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
G Outlook 2007 compound (OR) instant search break down Using Outlook 14
M How do I link a drop down box to a percent complete box Using Outlook 4
R Display multiple accounts as drop down in the from field in New Mail Using Outlook 1
F Locking down Outlook 2003 Using Outlook 0
P PST reached maximum size- cant delete emails to slim it down Using Outlook 5
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
B BCM shuts down everytime I try to import/export or check for error BCM (Business Contact Manager) 10
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
S RE: Template with drop down Outlook VBA and Custom Forms 3
B RE: Why does Business Office Contact Manager shut down Outlook? BCM (Business Contact Manager) 3
C Drop Down Box in Email Template Outlook VBA and Custom Forms 2
T Trickle down info from updated Accounts to Contacts BCM (Business Contact Manager) 1
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
