Note field on general tab
alfonso
When I look at my list of contacts I want to see the note box on the general
tab (ie the blank box to the right of the address & tels), but I don't know
what the field is called so cannot drag it into the viewing list. Can anyone
help?
Alfonso
alfonso
I forgot to say I am using Outlook 2003 with XP
Alfonso
> help?
> Thanks
> Alfonso
G
G. Vemuganti
> Alfonso
> > help?
> > Thanks
> > Alfonso
It is the "Notes" field in the frequently used field listing .
G
G. Vemuganti
> Alfonso
> > help?
> > Thanks
> > Alfonso
Earlier, When I replied to this mail, I thought it is the "notes" filed.
But I am wrong. I am also looking for answer to the same question by
Alfonso.
Gangadhar
G
G. Vemuganti
"G. Vemuganti" wrote:
Alfonso,
It is the "Notes" field in the frequently used field listing . You can drag
" Notes" field from left box to right box in customizing the contact
current view. It will show up in the customized view.
But When I try to import or export to Excel the "notes" field , It is not
importing the cell contents properly.
Can anyone help?
> Thanks,
> Gangadhar
G
G. Vemuganti
> Alfonso,
I made some progress. I was able to import the cell contents of the notes
field from an excel file by adding ' in front of the text in the cell. But
when export the contacts the notes field is exported as 0, even though there
is text in the field. Also I put ' in front of the text field like I did
when I was importing.
> Can anyone help?
> > Thanks,
> > Gangadhar
J images on note field display fraction of size Using Outlook 5
mrje1 Note Field (Any way to do incell editing) Using Outlook 7
U No scrolling in note field of contact record Using Outlook 1
L Contact Photo For Calendar Note Field Using Outlook 4
L Contact Photo For Calendar Note Field Using Outlook 0
L How to acess the note field in contact item Outlook VBA and Custom Forms 19
L Source Name for Appointment Note/Message field Using Outlook 0
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
W Get a "New Note" icon onto the QAT Using Outlook 3
D IMP.Note Versus REPORt.IPM.NOte Outlook VBA and Custom Forms 3
M One Note as a mail folder Using Outlook 6
L Outlook 2007 Code for Note Fields of Appointment Using Outlook 102
L Outlook 2007 Contact Form - Note Fields Using Outlook 25
W Calendar Note Font Reverting Using Outlook 11
M Unable to search Note section in Contacts in icloud Using Outlook 7
J add note to body or notes Outlook VBA and Custom Forms 5
S Note: The GMT offset above does not reflect daylight saving time adjustments Using Outlook 12
D Outlook VBA forward the selected email to the original sender’s email ID (including the email used in TO, CC Field) from the email chain Outlook VBA and Custom Forms 3
S Combination Field (Date Format) Outlook VBA and Custom Forms 0
C Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
V Checking for empty field Outlook VBA and Custom Forms 2
