Save CommandBar position problem?
  • Thread starter Thread starter ryotyankou
ryotyankou
I write my code by reference this link.
http://msdn.microsoft.com/en-us/library/ms268891.aspx
But there is a problem while i get the CommandBar position value.(Get value
before Save to registry).
My process is load registry value in OnConnection event, and Save to registry
in OnBeginShutdown event. In OnBeginShutdown event i got my error:
spCmdBar->GetPosition(); spCmdBar is CommandBar created. return error code is
0x800a01a8, it is strange GetPosition failed. In inspector wrapper which
process new inspector, the toolbar create there is ok while inspector is
closed. Any idea? TIA.
Use the Explorer.Close() event to tell you when to save toolbar positions
for an Explorer toolbar.
"ryotyankou " <u48591@uwe> wrote in message
news:97a1b7030395a@uwe...
> value
> registry
> is
Greate, it works, thank you, ken ^_^
> [quoted text clipped - 9 lines]
R Unable to save complete email to File Explorer Using Outlook 3
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
