Perform Search and Display Results
  • Thread starter Thread starter spottedmahn
spottedmahn
I'm trying to figure out how to select a specific Mapi Folder in Outlook,
load up the search field, start the search and display the results.
Currently I'm able to select the folder and display it but I can't figure
out how to enter text into the search field and start the search.
The folder I'm selecting is a contact mapi folder.
Please see this Live blog entry for clarification on what I'm trying to do.
https://login.live.com/login.srf&rp...s!CF657615B69F016B!368.entry&id=73625&lc=1033
The link did not post properly... trying again
http://spottedmahn.spaces.live.com/blog/cns!CF657615B69F016B!368.entry&sa=157594121
In Outlook 2007, take a look at the Explorer.Search method, which uses the
same DASL syntax as the AdvancedSearch method, but displays the results in
the UI instead of filling a result set.
Sue Mosher
"spottedmahn" <spottedmahn> wrote in message
news:B94BB412-619D-4193-AE5C-4D17417644A7@microsoft.com...
> > do.
Thanks Sue!
> > Sue Mosher
> >> do.
Diane Poremsky How to perform a global search and replace Using Outlook 0
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
E you don't have permission to perform this action exchange 2016 Exchange Server Administration 0
I There is no email program associated to perform requested action Using Outlook 0
G Hae Rules NOT perform automatically? Using Outlook 1
S Perform calculation in task fields Outlook VBA and Custom Forms 1
J Perform actions when email is sent Outlook VBA and Custom Forms 1
V How to disable Server Assisted Search Using Outlook 2
C Search bar moved on its own? Using Outlook 4
A Search People>press enter box disappears. Using Outlook 3
efire9207 Addressbook Search Using Outlook 4
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
A 'search people' now asks me to 'press enter' Using Outlook 11
A Relocate Search Bar in Outlook Using Outlook 2
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
P Outlook 2013 search no longer works Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
J search doesn't find anything Using Outlook 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
