Email body and signature help
joave
Hi:
I am attempting to insert specific text into the body of an HTML message
using Word as the editor with VBA. However, when I change the body of the
message, my signature disappears. Can someone please tell me how to keep the
signature in the message while inserting additional text? I have tried
several different methods but none seem to work.
Here is my current code (with some failed attempts at the above goal):
Dim objOLApp As Outlook.Application
Dim NewMail As Outlook.MailItem
Set objOLApp = New Outlook.Application
Set NewMail = objOLApp.CreateItem(olMailItem)
NewMail.Display
NewMail.To = "CF Reports"
NewMail.Subject = "Report " & Date - 1
Dim Temp As String
Temp = "Hi Team, </br>" & vbCrLf & vbCrLf & " Here is the latest Report.
Please let me know if you have any questions." & vbCrLf & vbCrLf & "Thank
you,"
Temp = Temp & vbCrLf & vbCrLf & "David " & NewMail.HTMLBody
NewMail.HTMLBody = Temp
'NewMail.Body = Temp
Thank you in advance,
Dave
Sue Mosher [MVP]
Call the message's Display method, get the HTMLBody (which will have the
signature at that point), and modify HTMLBody to include your new text. If
you know what the signature looks like, it may be easiest to use the
Replace() function to find the beginning of the signature and replace it
with your_new_text+beginning_of_signature.
Sue Mosher
"joave" <joave> wrote in message
news:97169C74-4654-48B1-A135-4BE2BC512494@microsoft.com...
> Hi:
> the
> NewMail.Display
> Dim Temp As String
> you,"
> Dave
joave
Hi Sue,
Thank you for your reply. This is where I thought this would go (there are
never any magic answers LOL). I was hoping to be able to use the picture that
is in my signature without having to replace the entire body, but it looks
like that will be very difficult to do.
Thanks again,
Dave
> > Sue Mosher
> > Hi:
> > the
> > NewMail.Display
> > Dim Temp As String
> > you,"
> > Dave
C
Curt
Can you direct me as to getting a picture into a signature macro in Outlook
2000 useing XP. Have done macros in excel but outlook is not same. Copying
excel does not work. Am not sure where to start. Macro would then contain
signature & picture when inserting into outgoing mail
> > Sue Mosher
> > Hi:
> > the
> > NewMail.Display
> > Dim Temp As String
> > you,"
> > Dave
Michael Bauer
If you want to send the image with the email, you need to embed it. This
example demonstrartes how to do that:
http://www.vboffice.net/en/developers/embed-pictures-in-email
Best regards
Michael Bauer
Am Sun, 27 Dec 2009 22:03:01 -0800 schrieb Curt:
Outlook
> Thanks
If
>> > > Sue Mosher
> >> Hi:
message
the
> >> the
> >> NewMail.Display
> >> Dim Temp As String
Report.
"Thank
> >> you,"
>>> Dave
K Incorporate selection from combobox into body of email Outlook VBA and Custom Forms 0
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
G Place jpg in body of email Outlook VBA and Custom Forms 1
A Forwarding email and replacing body Outlook VBA and Custom Forms 1
M Want to autorespond to an email address in the body of message Using Outlook 0
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
J Pull an email address from body and replace reply-to address Outlook VBA and Custom Forms 4
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
E Button in body of email to approve/reject with original text Using Outlook 1
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
M Sending Excel Charts in the Body of an Email Using Outlook 1
E Automatically pick up Recipient's Name on the Body of the Email Message Using Outlook 1
A Create Task from Email and put body & email as attachment into task notes Outlook VBA and Custom Forms 17
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
A Macro to copy email body to new email Outlook VBA and Custom Forms 5
R Body of email not visible in Outlook Data File Sent Folder Using Outlook 4
S Pre populate subject + body + attachment to already open email in outlook 2007 Using Outlook 2
G Create rule based on image in email body Using Outlook 1
F Script needed for replying to email address in body of receiving email Using Outlook 46
S email body without "HYPERLINK" ( vba ) Using Outlook 6
I can't view email body please help! Using Outlook 6
D Email addresss in body of email with single quote Using Outlook 3
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
L Script to: Change subject of email after checking body Using Outlook 2
H Extract emails from Outlokk 2007 email body Using Outlook 0
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
