Create rule based on image in email body
geedaddy
I keep getting spam emails with different senders, different subjects, different in every way except for the same text box at the end that supposedly is a link to unsubscribe. The link goes to a page that says I am unsubscribed, and perhaps I am from a particular email, but I continue to get more with the same text box content in every one. Is there a way to write a rule based on the contents of a text box (image) at the end of the body of an email? Thanks.
the only way to use a rule is if the image is linked by the same text, or the image name is always the same. Scroll to the very bottom of the email, right click and choose view source to see how its linked.
You can paste the code used for the link here, replace your email address with my@address. You may need to replace the angle brackets with something - curly { } or parens ( ) will work if needed.
D Create Exchange Rule for everyone that highlights an email based on content of subject Exchange Server Administration 1
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
Diane Poremsky Create a Task from an Email using a Rule Using Outlook 0
I Create custom Outlook 2013 Rule in Office 365 Outlook VBA and Custom Forms 5
S Create a Rule Using Outlook 0
I shared mailbox - can i create a rule (vba) for every user? Outlook VBA and Custom Forms 1
S How can I create a rule to move inbound emails from any of my contacts out of Inbox? Using Outlook 1
L How to create server-side rule? Using Outlook 4
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
Jennifer Murphy How to create a rule for organization messages Using Outlook 2
anoble1 Can you create a rule once an email moves to the Vault Inbox to another place? Using Outlook 0
S Create rule to effect archive only Using Outlook 4
C Create a rule to only check new content in email - disregard original content Using Outlook 3
M Create Rule to BCC email? Using Outlook 2
J Create or Import a Outlook Rule through C# code. Outlook VBA and Custom Forms 2
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How to create hidden rule in outlook 2007 Outlook VBA and Custom Forms 3
Q How do I create a custom action for a rule? (Save as "Nfy.MSG") Outlook VBA and Custom Forms 1
