Re: save certain emails from inbox to network drive with a macro
  • Thread starter Thread starter Ken Slovak - [MVP - Outlook]
K
Outlook has no macro recorder. You write macros in Outlook using VBA code
that you have to write from scratch.
You can select items in a folder, get the Selection collection for that
window (Explorer) and iterate the Selection. For each selected MailItem you
can use the SaveAs() method to save the items and then delete the item using
a count down loop.
You might want to search for code similar to what you want to get you
started at www.outlookcode.com
"Herb Segal" <hsegal@rcn.com> wrote in message
news:FC4621FB-681E-423B-BF8A-93EBCBD507FE@microsoft.com...
> Is there a way to create a macro that, when run, will save an email from
> my inbox to a folder on our network? I also thought a macro would not only
> save to a network folder but also delete from my inbox. Not every email in
> my inbox but only the ones I want to save.
> I use drag and drop now but thought the macro might make it a little
> easier. When I'm in MS outlook I can't always see my desktop so drag and
> drop if difficult. I'm constantly closing or minimizing programs so I can
> see the folder I want to drag to.
> I gather there is no record function in ms outlook like you find in excel.
Thank you very much.
news:uiROzr8WKHA.844@TK2MSFTNGP05.phx.gbl...
> you can use the SaveAs() method to save the items and then delete the item
> using a count down loop.
> > only save to a network folder but also delete from my inbox. Not every
> > email in my inbox but only the ones I want to save.
> > excel.
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
