BCM 2010 Beta - Sharing issues
Ron
I cannot for the life of me get this database to Share. I have completely
removed and reinstalled BCM and SQL 2008 from both computers, deleted the SQL
Server directory from the program files (x86). I have installed Office 2010
beta 64 and BCM 2010 beta 64. The following message is persistant...
"The computer, NAME, does not contain any shared Business Contact Manager
databases. Please confirm that a shared Business Contact Manager database is
stored on the computer"
This is driving me insane but then I again I am used to these types of
problems with BCM. It is VERY hard to implement!
Ron
P
PowerConcepts
Ron
I ran into the same issue on one computer and I realilzed that on that
computer I had renamed the user. When you rename the user somewhere in the
background it still is stuck on the original name. I suppose this is a
security issue so that someone cannon simply rename the user of a computer
and get access to the BCM. I had to create a new user on the computer and
begin to use that. In so doing the username is consistent through out the
the Windows records. Once I did this and shared the BCM it worked perfectly.
One sub note is that for BCM to work properly each of the users must be
using a username and password on their Windows login. Use the exact same
username and password when setting up the share on the BCM.
Hope this helps.
Frank
> Ron
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
V Permissions in BCM 2010 BCM (Business Contact Manager) 3
M Is there a list of FieldNames that BCM 2010 uses? BCM (Business Contact Manager) 0
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
N BCM 2010 for CRM tool? BCM (Business Contact Manager) 3
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
Forum Admin Download BCM 2010 BCM (Business Contact Manager) 0
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
R Missing contacts and Opportunities in BCM 2010 Shared database BCM (Business Contact Manager) 1
M BCM for Outlook 2010 now on Technet BCM (Business Contact Manager) 2
J BCM 2010 BCM (Business Contact Manager) 1
G Small Businesses Owners being priced out of BCM 2010 BCM (Business Contact Manager) 2
J Where is Final Release BCM 2010, Microsoft? Why is Dev Team silent BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
B Where is RTM version of BCM 2010? BCM (Business Contact Manager) 2
R BCM 2010 error creating offline copy of shared database BCM (Business Contact Manager) 1
C BCM for RTM Release of Outlook 2010 BCM (Business Contact Manager) 3
K BCM 2010 report error BCM (Business Contact Manager) 6
B Multiple businesses in BCM 2010 BCM (Business Contact Manager) 9
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
J Installing BCM 2010 on Server and Custom Form Layouts BCM (Business Contact Manager) 2
A BCM 2010. Cannot open this item. Error loading form. Some of neede BCM (Business Contact Manager) 3
M BCM 2010 changes BCM (Business Contact Manager) 1
