Java script issue OWA Exchange 2010
exchange
Hello guys!
After installing Exchange 2010 i noticed that every time I log in OWA it freezes. In the bottom left corner it indicates that there is problem with web page and when I open the notification it says that URI: https://********.com/ecp/14.0.639.21/Scripts/common.js Access denied. The same happens if I redirect link to owa, then instead I get message that says Access is denied to file:
URI: https://********.com/owa/14.0.639.21/Scripts/uglobal.js. I tried to search on google and see if people had similar issue but I didn´t find anything...
I tried to use different web browsers ( Firefox, IE8 and Conqueror) and OWA freezes with Firefox and IE8 but it works fine with Conqueror...
Apreciate if You could help me out!
I would like to hear the solution because I am having the same issue.
Yes, please send what the fix was. We are experiencing the same issue.
It's doubtful that you'll get a reply at this point in time (the thread is 2 yrs old). However, if its an access denied error on scripts running on the server, its permissions (on the OWA web server).
Thanx for all replays and good tips lads! :O
Nevermind, I managed to solve the problem by myself
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
R Script for simplifying spam control Outlook VBA and Custom Forms 7
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
