VSTO_SUPPRESSDISPLAYALERTS not working on target PC
  • Thread starter Thread starter Mark B
Mark B
OL2007, C#, VSTO.
Does the http://msdn.microsoft.com/en-us/library/ms269003(VS.80).aspx
article shown below relate to the deployment machines as well as the
development machine? On one of my Vista deployment test machines, no log
file has been created and no popup message boxes appear even though I have
added the environment variables as described below. I am trying to find the
cause of the Addin being made inactive even though it works fine on the
development machine.
Troubleshooting Add-ins Using a Log File and Error Messages
Visual Studio Tools for Office can write all errors that occur during
startup to a log file or display each error in a message box. By default,
these options are turned off for application-level projects. You can turn
the options on by adding and setting environment variables. To display each
error in a message box, set the VSTO_SUPPRESSDISPLAYALERTS variable to 0
(zero). You can suppress the messages by setting the variable to 1 (one). To
write the errors to a log file, set the VSTO_LOGALERTS variable to 1 (one).
Visual Studio Tools for Office creates the log file in the folder that
contains the application manifest. The default name is
<Manifestname>.manifest.log. To stop logging errors, set the variable to 0
(zero). For information about setting environment variables in Microsoft
Windows XP, see "How To Manage Environment Variables in Windows XP"
(http://support.microsoft.com/kb/310519).
That should work on deployment machines but only if the addin has actually
been loaded. If there are load errors that occur before the addin is started
(and also if the CAS hasn't been set correctly I believe) VSTO won't do the
logging because the VSTO addin never started.
See
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
for load error logging information and also make sure you have set full
trust on your VSTO addin, which is required for a VSTO addin to run.
"Mark B" <none123@none.com> wrote in message
news:OkFmyeoiKHA.2132@TK2MSFTNGP05.phx.gbl...
> OL2007, C#, VSTO.
> the cause of the Addin being made inactive even though it works fine on
> the development machine.
> each error in a message box, set the VSTO_SUPPRESSDISPLAYALERTS variable
> to 0 (zero). You can suppress the messages by setting the variable to 1
> (one). To write the errors to a log file, set the VSTO_LOGALERTS variable
> to 1 (one). Visual Studio Tools for Office creates the log file in the
> folder that contains the application manifest. The default name is
Thanks Ken.
On further inspection of the Setup project my associate created, I notice he
didn't include the VSTO Runtime at all. So once I manually installed that on
the target machine after downloading it from Microsoft it all worked OK.
I now have asked him to research how to get that VSTO Runtime and the PIA
installed as part of the Setup project -- albeit silently. Hopefully he'll
be able to amend the Setup project to do that. It's for Enterprise rollout
so we don't want any user interaction whatsoever.
Thanks for your help.
news:%23BsPitWjKHA.2160@TK2MSFTNGP02.phx.gbl...
> started (and also if the CAS hasn't been set correctly I believe) VSTO
> won't do the logging because the VSTO addin never started.
> See
> > OL2007, C#, VSTO.
> > have added the environment variables as described below. I am trying to
> > find the cause of the Addin being made inactive even though it works fine
> > on the development machine.
> > 0 (zero). For information about setting environment variables in
> > Microsoft Windows XP, see "How To Manage Environment Variables in Windows
> > XP" (http://support.microsoft.com/kb/310519).
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
M VSTO deployment? Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
Commodore Automatic switch between working offline/online Using Outlook 4
