How to delete Messages in ascending order - Outlook 2010
  • Thread starter Thread starter heater
H
heater
When I highlight a message (Outlook 2010) in the in box to delete and after
deletion, I want the cursor to move up to the message above it and not below
it.
Then reverse the order the messages are in so the newest is at the bottom.
> it.
That does not accomplish what I want. In Outlook 2003, there was an option
under tools that you could click to make it go up instead of down.
> > it.
Try File, Options, Mail - at the very bottom of the dialog is the option to select/open the next item, the previous or return to the folder after deleting and item.
Otherwise, it depends on the sort order in the folder.
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
O How to delete duplicate RSS messages? Using Outlook 6
F delete unsended messages Using Outlook 1
E How will I delete messages permanently? Using Outlook 2
T How to remove "automatically delete messages form this sender"? Using Outlook 1
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
F Automatically delete previous messages in a conversation Using Outlook 2
A Delete messages on server Outlook VBA and Custom Forms 1
F Outlook 2021 Inbox delete icon missing Using Outlook 5
T Cannot delete a calendar Using Outlook 0
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
A Outlook 365 Delete entries in title field, address book Using Outlook 0
D Delete Outlook emails from MS server Using Outlook 17
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
G Automatically delete email when a condition is met Outlook VBA and Custom Forms 1
M Shift Delete doesn't delete email from server Using Outlook 3
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
O How to delete a forum post? Using Outlook 4
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
O Delete duplicate emails - subscription notifications Using Outlook 5
