populate body with Word data
Si4gRnJlZWQ
I have an Access DB with a field containing a Word doc as an embedded object.
I think I can retrieve the contents but I can't seem to figure out how to
populate them into the body of the message in VBA. I've seen a few postings
on this subject and I seem to be missing how to actually populate the body.
Any ideas? TIA.....
Sue Mosher [MVP]
Once you have your Word.Document object, you can use the technique shown at
http://www.outlookcode.com/codedetail.aspx?id=1333.
Sue Mosher
"J. Freed" <JFreed> wrote in message
news:D28BDE83-F73E-4E60-8605-7C1FE08B323D@microsoft.com...
> object.
> postings
> body.
> Any ideas? TIA.....
Si4gRnJlZWQ
It worked. Thanks!
> > Sue Mosher
> >object.
> > postings
> > body.
> > Any ideas? TIA.....
J. Freed
This is working well. Now, I need to be able to add data from tables/forms in
addition to the Word data. When I try to add to the body the Word data
disappears, so I'm guessing I need a way to add the data I want to the Word
doc before it gets posted to the note.
TIA.
"J. Freed" wrote:
> It worked. Thanks!
> > > > Sue Mosher
> > >object.
> > > postings
> > > body.
> > > Any ideas? TIA.....
Sue Mosher [MVP]
That's probably the best way to do it, to preserve formatting, etc.
Sue Mosher
news:13AB3DE1-D63A-4535-A4BA-3D56152F36AC@microsoft.com...
> in
> Word
> TIA.
> "J. Freed" wrote:
> > It worked. Thanks!
> > > shown at
> > > >object.
> > > > how to
> > > > postings
> > > > body.
> > > > Any ideas? TIA.....
J. Freed
I agree. Problem is, I have no idea how to do it. How would I take a field in
a form (or a table) and copy it into the Word doc generated by the code below:
Forms!fcp_new!wire.Verb = 0
Forms!fcp_new!wire.Action = 7
Forms!fcp_new!wire.Object.Application.ActiveDocument.Content.Select
Forms!fcp_new!wire.Object.Application.Selection.Range.Copy
Forms!fcp_new!wire.Action = 9
wd.ActiveDocument.SaveAs "L:\Operate1\ELPD_Middle_Office_Reports\OTC
Payments\eos.doc"
Set doc = wd.Documents.Open("L:\Operate1\ELPD_Middle_Office_Reports\OTC
Payments\eos.doc")
wd.Selection.Range.Paste
Payments\eos.doc"
which takes data from an OLE object in a table and copies it into a Word
doc, which then gets posted to the body using
Set itm = doc.MailEnvelope.Item
TIA......
> > Sue Mosher
> > in
> > Word
> > TIA.
> > "J. Freed" wrote:
> >> It worked. Thanks!
> >> > shown at
> >> > >object.
> >> > > how to
> >> > > postings
> >> > > body.
> >> > > Any ideas? TIA.....
Sue Mosher [MVP]
Instead of wd.Selection.Range.Paste, you can use:
wd.Selection.Range.InsertAfter "some text"
or
wd.Selection.Range.InsertAfter some_string_variable_value
Also, the Word macro recorder can be your friend in these situations to show
the useful methods for a given scenario.
Sue Mosher
news:4657EFBE-B28D-48CC-8811-388FF2E6D2A8@microsoft.com...
> in
> below:
> Payments\eos.doc"
> Payments\eos.doc")
> Payments\eos.doc"
> End If
> TIA......
> > > > Sue Mosher
> > > tables/forms
> > > in
> > > Word
> >> > TIA.
> >> > "J. Freed" wrote:
> >> >> It worked. Thanks!
> > >> > shown at
> > >> > >embedded
> > >> > >object.
> > >> > > how to
> > >> > > postings
> > >> > > the
> > >> > > body.
> > >> > > Any ideas? TIA.....
J. Freed
That did the trick. Thanks again!
> or
> > Sue Mosher
> >in
> > below:
> > Payments\eos.doc"
> > Payments\eos.doc")
> > Payments\eos.doc"
> > End If
> > TIA......
> >> > >> Sue Mosher
> >> > tables/forms
> >> > in
> >> > Word
> >> >> > TIA.
> >> >> > "J. Freed" wrote:
> >> >> >> It worked. Thanks!
> >> >> > shown at
> >> >> > >embedded
> >> >> > >object.
> >> >> > > how to
> >> >> > > postings
> >> >> > > the
> >> >> > > body.
> >> >> > > Any ideas? TIA.....
J Live Meeting Location populate from body Outlook VBA and Custom Forms 4
S Pre populate subject + body + attachment to already open email in outlook 2007 Using Outlook 2
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
A Populate Listbox from Txt File Outlook VBA and Custom Forms 0
A Populate Textbox from Txt File Outlook VBA and Custom Forms 1
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox Using Outlook 0
T populate calendar with appointments and send reminders Using Outlook 1
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
A How can I populate a dropdown list? BCM (Business Contact Manager) 4
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
A Cannot populate IMAP folders Using Outlook 1
S Populate textbox values from one form to another form. Using Outlook 0
B Auto Populate From Field Using Outlook 3
G Populate an Outlook 2007 template with spreadsheet data. Outlook VBA and Custom Forms 1
R Populate Form with appointments from Calendar Outlook VBA and Custom Forms 1
J populate word template from Outlook custom form Outlook VBA and Custom Forms 2
G Populate BCC field with all Contacts within a Contact Folder Outlook VBA and Custom Forms 4
M Create new Contacts folder and populate it from Access Outlook VBA and Custom Forms 1
A Macro - Open new message, populate from and subject fields, and message text Outlook VBA and Custom Forms 1
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
L how to populate multiple users contacts Outlook VBA and Custom Forms 9
A Populate task field based on value of other field Outlook VBA and Custom Forms 9
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
Beeto Replace a string in body Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
