how to populate multiple users contacts
  • Thread starter Thread starter LDSPowershell
L
LDSPowershell
Is there a way to add contacts to multiple accounts using powershell
or c# or vb. I've done a lot in powershell, a little in c# and none
in vb. I'll accept any of the above if someone could give me a head
start.
Do you mean in multiple Exchange mailboxes?
Sure, call Application.Session.GetSharedDefaultFolder(...,
olFolderContacts), then call Folder.Items.Add to create a new contact
Dmitry Streblechenko (MVP)
"LDSPowershell" <nixonjl@gmail.com> wrote in message
news:29c6d49d-dc8e-4106-aa6c-eabbb29864fd@s16g2000vbp.googlegroups.com...
> start.
Correct, multiple brand new accounts, exchange 2007. I'm assuming
thats vba, thanks for the info.. it looks like i'll have to grab a
vba book, i've always wanted to learn a bit about vba.
On May 11, 12:40 pm, "Dmitry Streblechenko" <dmi...@dimastr.com
> OutlookSpy  - Outlook, CDO
> -"LDSPowershell" <nixo...@gmail.com> wrote in message
> > start.
> >news:29c6d49d-dc8e-4106-aa6c-eabbb29864fd@s16g2000vbp.googlegroups.com....
> > > start.
ok, so its looking that is c#. I've just never used it in this way...
I'm not an expert by any means but I can dig around and usually get
things to work.
It does not really matter what language you are using.
What exactly are you having problems with?
news:1d43da96-423c-4bae-ba82-f9225ccb4545@q2g2000vbr.googlegroups.com...
> > > start.
things to work.
> > > > start.
> things to work.
Im migrating some accounts to exchange and have ldap'd their old
contacts and put them in a csv file. I would like to have them
populated into the new accounts for the users. it can be a bit
difficult for a user to select import from the file menu and follow
the prompts... so it would save a few calls to have them already
populated when they open outlook. im just looking for an semi
automated way to get them in. i can go into each account and import
them in, but I really don't want to do that
Did you start writing any code?
Is there a specific Outlook object or method that you are having problems
with?
> with?
Im sitting in visual studio right now playing with code. no problems
yet that I need to ask question about, again Im not an expert in c# or
studio, but the web is a beautiful thing when it comes to finding how
to do things! which do you think would be easier, vb or c#?
It is whatever you are most comfortable with :-)
I'd personally prefer C#.
after I asked about vb or c# I realized that its really .net
right--- thats why you say it doesn't matter. its all coming
together...I'm new to the MS thing but am finding it enjoyable.
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
A Populate Listbox from Txt File Outlook VBA and Custom Forms 0
A Populate Textbox from Txt File Outlook VBA and Custom Forms 1
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox Using Outlook 0
T populate calendar with appointments and send reminders Using Outlook 1
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
J Live Meeting Location populate from body Outlook VBA and Custom Forms 4
A How can I populate a dropdown list? BCM (Business Contact Manager) 4
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
A Cannot populate IMAP folders Using Outlook 1
S Pre populate subject + body + attachment to already open email in outlook 2007 Using Outlook 2
S Populate textbox values from one form to another form. Using Outlook 0
B Auto Populate From Field Using Outlook 3
G Populate an Outlook 2007 template with spreadsheet data. Outlook VBA and Custom Forms 1
R Populate Form with appointments from Calendar Outlook VBA and Custom Forms 1
J populate word template from Outlook custom form Outlook VBA and Custom Forms 2
G Populate BCC field with all Contacts within a Contact Folder Outlook VBA and Custom Forms 4
M Create new Contacts folder and populate it from Access Outlook VBA and Custom Forms 1
A Macro - Open new message, populate from and subject fields, and message text Outlook VBA and Custom Forms 1
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
S populate body with Word data Outlook VBA and Custom Forms 7
A Populate task field based on value of other field Outlook VBA and Custom Forms 9
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 3
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
