Appointment time will not display
massagerbyday
I have a 2007 version of Outlook installed on two separate computers. When I try to create an appointment and select the start and end time for that appointment, it will not display the appointment start time in the calendar. It works on my other computer where I have Outlook installed. Are there default settings that I need to check off so that start times will show in the calendar?
That did it...I just couldn't put my finger on it but totally makes sense.
Thanks for the feedback
M Display time in an appointment in week or dayview Using Outlook 1
Y Q's on Appointment Reminders Using Outlook 2
B Linking contact to an Appointment Using Outlook 1
O Calendar - appointment templates and categories Using Outlook 1
W Appointment userproperties disappear Outlook VBA and Custom Forms 4
F Appointment Show All Fields Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
W Appointment occurrences change the location property Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
A Day view - print appointment details Using Outlook 1
R Recover Deleted Appointment in Calendar Using Outlook 0
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
S Appointment colour categories disappear Using Outlook 4
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Create Task or Appointment and Insert Selected Text Using Outlook 0
Pierce007 Maps/location in making an appointment Using Outlook 2
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Create Appointment From Email Automatically Using Outlook 0
P Appointment times are off by one minute Using Outlook 1
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
