Was Helvetica crashing Outlook, now fix has messed up explorer
pamrr
I downloaded and installed the fix for the glitch that was crashing my Outlook (because of Helvetica True Type 1 font), and my Outlook works fine. But now explorer is acting up. When I go to some of my sites, I get a black screen. Other sites, like this one, it partly freezes up.
Please tell me how to uninstall this patch. I will find some other way...pay for the Open Face version of Helvetica, and in the future, maybe not use MS products.
Pam
PS, I am coming in through Firefox. Thank goodness explorer worked enough to let me install another browser!
One more thing, I re-deleted Helvetica, which solved that problem. So I am back to square one. I will have to purchase a new set of Helvetica, bummer. $99. I've been a big Microsoft fan up until now.
Pam
Hmmm. That's a new one. Should be able to unistall it in Control panel, programs or use system restore to roll back.
Have you seen this article - http://kb2.adobe.com/cps/860/cpsid_86033.html ? Adobe has some font files for download.
Thanks, Diane. I downloaded and installed the fonts available at adobe, and both Outlook and explorer appear to be working, so far.
S Email was migrated from GoDaddy to Microsoft exchange. We lost IMAP ability Exchange Server Administration 1
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
L Creating drafts when I thought I was sending Using Outlook 1
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
wisedave Missing icon that show message was forwarded, etc Using Outlook 1
P Item cannot be saved because it was modified by another user or window Using Outlook 8
S Can't move the items. The item could not be moved. It was either already moved or deleted, or access Using Outlook 3
G Reply using address a message was sent to Using Outlook 2
C Whose brilliant idea was to make it more difficult to scroll in Outlook? Using Outlook 0
D See Email Address Received Email was Sent To? Using Outlook 1
D Will Outlook 2010 work with Office 2013 H&S that was preinstalled Using Outlook 2
A automatically remove flag from original message when a response was received Using Outlook 2
E My Outlook 2010 contacts list was hijacked! Using Outlook 10
J View the date a contact was created Using Outlook 7
A When was an item deleted Using Outlook 1
P the outlook 2007 calendar cannot be saved because it was changed by another user or in another windo Using Outlook 4
R Error Message: There was an error generating the XML document BCM (Business Contact Manager) 2
J Can't run macro Outlook 2007 that was created in Word 2007 Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
Z Check if email was sent Outlook VBA and Custom Forms 1
P fix for Helvetica crasing Outlook 2010? Using Outlook 5
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
P Questions On Crashing, Sluggish, and Configurations Using Outlook 1
C Outlook (365) is crashing as soon as its opened Using Outlook 2
L Outlook Office 365 cached mode crashing Using Outlook 0
E Gmail crashing Outlook Using Outlook 2
C Outlook Crashing on Specific BCM Lead File BCM (Business Contact Manager) 2
J BCM Crashing with Add-in Enabled in User Mode BCM (Business Contact Manager) 2
F Difficult Oulook Crashing Problem Using Outlook 1
D outlook keeps crashing with cLucene error Using Outlook 2
J Checking PST File Keeps Crashing Using Outlook 2
U Need a help please Outlook 2007 crashing Using Outlook 2
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
Q Constant crashing BCM (Business Contact Manager) 2
P pasteface method crashing outlook Outlook VBA and Custom Forms 7
B RE: Outlook 2007 - SMS Link (mobile text) crashing outlook Outlook VBA and Custom Forms 1
