Mail in Control Panel Won't Launch
David_H
I'm in the progress of trying to migrate to a different Exchange hosting partner. I was starting to set up a new profile and now not only won't Outlook launch, but I can't even launch the mail icon in control panel. I thought I might have a corrupt profile - could that even stop the mail app in control panel from launching??
I did some Googling and only found a few references to this issue, I guess I am lucky :-). Any suggestions? I'm guessing maybe I need to delete something in the registry?
When I said it won't launch, that's what I meant :-). No error message, no nothing, the screen flashes as if it is trying to launch, then nothing happens.
As far as Outlook goes, if I try to launch it one of two things happens. First time it just doesn't start and same thing with subsequent attempts. So I go in and find idle Outlook processes running and force them closed. Next time I try to open it warns me that Outlook could not open the last time and asks if I want to open it in safe mode. I click yes and it still doesn't open. Then if I try to launch again it asks me if I want to repair and if I click yes it runs through a repair process that does nothing to fix the problem.
Found the profiles in the registry and deleted them. That fixed it. Interestingly, just deleting them would not do it, I also had to restart.
J Control Panel Mail (settings) icon missing Using Outlook 2
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
Rupert Dragwater Mail won't show as read Using Outlook 2
O Junk E-mail Options disabled(?) Using Outlook 3
E Replying to a plain text e-mail with HTML Using Outlook 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Exchange Server - Mail Delay Stamping Exchange Server Administration 0
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
A manual rule sends mail to wrong folder Using Outlook 5
Cathy Rhone Mail merge error message Using Outlook 1
