Reccuring appointment issues
awl83usa
Hello
someone sent me a reoccurring meeting but I need to change the start time back a hour for the series but I try to edit it I change everything but the time I am using exchange 2010 and outlook 2007
Any help you could give would be great
awl83usa
You can't change the time on meetings you are invited to. You'll need to create another appt for the extra hour. Copying the appt may allow you to change the time on the copy - but you'll still need two appt on your calendar (the original and the copy).
Y Q's on Appointment Reminders Using Outlook 2
B Linking contact to an Appointment Using Outlook 1
O Calendar - appointment templates and categories Using Outlook 1
W Appointment userproperties disappear Outlook VBA and Custom Forms 4
F Appointment Show All Fields Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
W Appointment occurrences change the location property Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
A Day view - print appointment details Using Outlook 1
R Recover Deleted Appointment in Calendar Using Outlook 0
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
S Appointment colour categories disappear Using Outlook 4
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Create Task or Appointment and Insert Selected Text Using Outlook 0
Pierce007 Maps/location in making an appointment Using Outlook 2
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Create Appointment From Email Automatically Using Outlook 0
P Appointment times are off by one minute Using Outlook 1
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
Diane Poremsky Create an Appointment Diary Using Outlook 0
