Default for full Justification
David Lee
In Outlook 2007, there was a normal email template. I modified it and anytime I created an email, it was set up exactly as I expected. I had Windows XP
I now have Outlook 2010 and Windows 7. I cannot find a template anywhere. When I try to modify the styles, even though I click the box to apply to future documents. How can I modify paragraphs, style, justification, font, etc. and keep them present whenever I start a new trip?
I have searched for various terms, but have not been successful in the searches.
You may need to open normalemail.dotm but first try this:
open a new message form. Go to the Format tab and choose change styles. Make you changes in that command and then chosoe set as default when finished. See +Biody style section near the end for screenshots and a tutorial
You can change the basics there and that is sufficient for most people but if you need to change more, open the template file in word and edit it. It's at %appdata%\microsoft\templates - you can paste that line in the address bar of windows explorer to jump to it.
T Default fields Using Outlook 3
V select default calendar Outlook VBA and Custom Forms 3
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
R Outlook ribbon menu default? Using Outlook 7
T How to set Default FONT for Email composing ? Using Outlook 0
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
P default font when sending email from browser Using Outlook 1
A force outlook to default to MY calendar Using Outlook 3
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
V Accepted meetings do not get the default reminder Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
