How do I get two calendars to display by default
nickwagner
I have two calendars, which are both in the same pst file: 1. Calendars and 2. TripCase.
When I open the Calendar in the morning, I want both calendars to display in the overlay view. I can make them display that way by clicking on both calendars in the sidebar panel. However, when I close Outlook and reopen it, only the first one, Calendars, is showing. I have to manually click on TripCase again to get it to display.
How do I get them both to display by default on opening?
Outlook 2010 should remember. When it doesn't, it usually means Outlook did not close completely.
Next time you close Outlook, check in Tasks Manager, Presses tab and verify outlook.exe is not running. Also, make sure you close Outlook a few minutes before shutting down windows - don't let windows close it for you. If you use a pst backiup tool or something that uses outlook data, it can interfere too.
Thanks for your reply Larry. I tried again. I checked Task Manager, and Outlook was not running. Same problem.
Nick
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
N Outlook 365 How to show all calendars at startup? Outlook VBA and Custom Forms 0
P Syncing Outlook & iPhone Calendars Using Outlook 4
J Multiple calendars Using Outlook 0
Graham Hyman Outlook 2016 Internet Calendars appearing as deleted Using Outlook 4
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
M Outlook 365 Searching all shared calendars Outlook VBA and Custom Forms 4
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
B Sharing Outlook calendars gone wrong Using Outlook 0
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
D Sharing calendars Exchange Server Administration 1
K Can VBA intervene when updating Internet Calendars? Outlook VBA and Custom Forms 5
L Calendars in Outlook 2016 Using Outlook 0
A Helping OL remember which calendars were selected Using Outlook 6
Diane Poremsky New in Office 365 and Outlook.com: Interesting Calendars Using Outlook 0
Diane Poremsky Combine and Print Multiple Outlook Calendars Using Outlook 0
Jeanne Goodman Create Printout from Multiple Shared Calendars Outlook VBA and Custom Forms 8
Diane Poremsky Publishing Calendars on the Internet or an Intranet Using Outlook 0
Diane Poremsky Select Multiple Calendars in Outlook Using Outlook 0
Diane Poremsky Sharing Outlook.com Calendars Using Outlook 0
C Merge two archive calendars Using Outlook 1
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
M Reminders or Notifications for Internet Calendars Using Outlook 1
Diane Poremsky Print Monthly or Work Week Calendars Using Outlook 0
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
H Other peoples calendars going on the left Using Outlook 1
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
M Un-needed Calendars Using Outlook 1
R Automating from excel into shared Calendars Using Outlook 1
M Not All Outlook.com Calendars Showing in Outlook.com Using Outlook.com accounts in Outlook 18
T populating multiple calendars without invites Using Outlook 1
T Consollidating all calendars to Outlook online, even from POP3 email invitations. Using Outlook 2
ACM Viewing Outlook calendars on multiple devices Using Outlook 3
P syncing outlook calendars Using Outlook 12
