Running macros in tasks sent out as meeting requests in invitees machine
milo_rait
How to execute macros in tasks that run in your machine in invitees machine.
The tasks are sent as meeting invites, but when the invitee saves the task, the macro is missing and task cannot be saved.
The macro works fine in my Outlook 2010
"code behind" a form only works if the recipient has the form published - this works best in Exchange server, where it can be published to the org forms library. Otherwise, the recipient needs a copy of the template so it can be published.
I have to send out a meeting invite to others that starts up a URL on reminder every weekday, how can I do this?
You can't do anything (if you could, spammers would have a field day) unless they have a VBA macro that will run when a reminder fires - then a properly designed meeting request with a reminder might work.
H running multiple macros at once Outlook VBA and Custom Forms 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
S CSCANPST To Automate Running SCANPST.EXE Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
A running code after the new inspector is visible Outlook VBA and Custom Forms 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
G Re:Running a Macro when email arrives Outlook VBA and Custom Forms 1
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
B Phantom VBA Running Outlook VBA and Custom Forms 1
M If loop not running Outlook VBA and Custom Forms 1
D Troubleshooting rule/script not running Outlook VBA and Custom Forms 5
P How to use a form from a rule running on the inbox Outlook VBA and Custom Forms 1
Q Running the Database from a Server BCM (Business Contact Manager) 7
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
S Outlook rules not running automatically Using Outlook 11
S Why do I have to close and reopen Outlook for macros to work? Outlook VBA and Custom Forms 2
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
