Script to: Change subject of email after checking body
Lucafonso
Hello to this large comunity,
I'm here to ask some help to create a rule ( if somehow possible ).
I receive daily automatic generated emails, and all of them have the same subject: "Orden de pedido"
And inside of the email is the serial number of the device that generated that alert.
I wanted to add to the subject the serial number that appear in body of email after the following sentence: "con el número de serie SERIAL NUMBER" ( serial number is what i want to copy to subject ).
Don't know if that is possible, it seems a great idea in my head.
( using Office 2010 32bits )
J Public folders woes (script to change subject line of messages) Exchange Server Administration 0
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
R Script for simplifying spam control Outlook VBA and Custom Forms 7
