Renamed folder staying at the same position
Commodore
Outlook 2021 64 bit
After a very long time I had to rename a mail folder in a PST file (not the default PST). Instead of the folder changing its (alphabetic) position as a result of the new name, it stayed in its place. I don't really remember if I ever renamed a folder in Outlook 2010, but I'm pretty sure the folder's position would be instantly updated in the hierarchy, at least in earlier versions. Is this some sort of a new bug?
Even more, a few hours later I'm noticing that a few other random folders were re-positioned randomly in that PST, now making even less sense than before... (I didn't restart Outlook just yet, though.)
yes that just i would like to say if it causes any error you can simply restart it.it will corrected automatically.
thanks!!
It's still probably a stupid 2010 bug, as I had never encountered it before.
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
I Renamed msg file Using Outlook 3
D Attachment renamed or exention change in error Using Outlook 2
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
G Keeping Outlook Classic (desktop) PST in Google Drive folder? Using Outlook 4
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 2
S Mail not showing in created folder Using Outlook 10
T Outlook 2010 Emailed folder but no 'From-To-Subject' information. Date okay. Using Outlook 12
Victor_50 Outlook 365 Jump to folder Outlook VBA and Custom Forms 3
S How to get the actual Public Folder path from Favourites Folders Outlook VBA and Custom Forms 3
D.Moore Outlook COM addins source folder Using Outlook 12
M Folder names - rich text Using Outlook 6
E Gmail folder -why, in .ost IMAP situation, as well as Googlemail folder? Using Outlook 0
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
B How to get PST folder datetime? Outlook VBA and Custom Forms 1
A Outlook 2019 folder counter Using Outlook 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 4
V Folder Properties - Gmail account can't switch Using Outlook 5
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
G Adding a contact to a specific folder Using Outlook 0
Rupert Dragwater Duplicate email in Folder Using Outlook 7
L "Insert Pictures" Button-Wrong Folder Using Outlook 5
CWM330 Outlook 365 Hey Diane! MS 365 Biz Standard and "Potential Spam" addressed to others coming to my JUNK folder? Using Outlook 2
